Why is my N-Body Simulation in Matlab Showing Errors?
The discussion revolves around a Matlab program designed to simulate the gravitational interactions of N bodies, specifically focusing on the motion of the Earth and the Sun. Participants explore issues related to the accuracy of the simulation, particularly concerning the initial conditions and the resulting trajectories of the bodies involved.
  • Exploratory, Technical explanation, Debate/contested
  • One participant describes the setup of their N-body simulation, detailing the use of either Euler or RK4 integration methods to calculate positions and velocities of the bodies.
  • Another participant suggests that the initial placement of the Earth relative to the Sun may cause a drift in the Sun's motion, indicating that the initial conditions need to reflect the proper motion of the Sun.
  • A third participant elaborates on the implications of starting the Earth with a velocity while keeping the Sun motionless, explaining that this leads to a net drift of the center of mass and results in a cycloidal path for the Sun.
  • A later reply acknowledges the previous points and recognizes that the initial conditions for the Sun's velocity should not be zero, indicating a realization that the code itself may not contain errors but rather the initial setup.
  • Participants also mention the ability to replicate other orbital patterns, such as a figure-eight trajectory, suggesting variability in outcomes based on different initial conditions.
Participants generally agree that the issues observed in the simulation stem from the initial conditions rather than errors in the code itself. However, there is no consensus on the best way to set these initial conditions, and the discussion remains open to further exploration of the topic.
The discussion highlights the importance of initial conditions in N-body simulations, particularly in gravitational systems, and points out the potential for drift in the center of mass based on the setup of the simulation.
Einstein2nd
Hello all.
I'm currently writing a program in Matlab that works out the positions of N bodies under the influence of gravity. The code is setup such that it only requires a mass and an initial position and velocity for each body. Any number of bodies can be entered but for testing purposes I am just using two.
The code uses either Euler or RK4 (fourth-order Runge-Kutta integration). The problem I am getting occurs with either type of integration. Firstly, here is the code:
Code:
clearvars
% UNIVERSAL CONSTANTS
G = 6.673*10^-11; % gravitational constant
Msun = 1.98892*10^30;
Mjup = 1.8987*10^27;
Mearth = 5.9742*10^24;
Mlunar = 7.349*10^22;
AU = 1.49598*10^11;
Vearth = 2.9786*10^4;
Vlunar = 1.076*10^3;
Tearth = 3.15576*10^7;
Tmoon = 2.36058*10^6;
% USER INPUTS
IntegrationMethod = 2; % 1 = Euler, 2 = RK4
N = 2; % The number of bodies
m = [1*Msun 1*Mearth]; % Mass vector
maxtime = 5*Tearth; % Maximum time to integrate over
npts = 500; % Number of integration points
% SETUP INTEGRATION
H = maxtime/npts;
% APPLY INITIAL CONDITIONS
r_old(:,:,1) = [0 0 0]; % Sun starts at the origin
r_old(:,:,2) = [0 AU 0]; % Earth starts 1 AU away
drdt_old(:,:,1) = [0 0 0]; % Sun is initially motionless
drdt_old(:,:,2) = [1*Vearth 0 0]; % Earth is moving perpendicular to the line joining it to the Sun
% SETUP FIGURE
close all
figure(1)
set(get(gca, 'xlabel'),'FontSize',20)
set(get(gca, 'ylabel'),'FontSize',20)
set(get(gca, 'title'),'FontSize',20)
colourarray = ['r','b','g','g'];% DO INTEGRATION
xlabel 'x'
ylabel 'y'
title 'N-Body Simulation'
axis equal
hold onfor i = 1:npts
    if IntegrationMethod == 1
        drdt_new = drdt_old + H*W(N,G,m,r_old);
        r_new = r_old + H*drdt_new;
    elseif IntegrationMethod == 2
        k1 = zeros(1,3,N);
        k2 = zeros(1,3,N);
        k3 = zeros(1,3,N);
        k4 = zeros(1,3,N);
        l1 = zeros(1,3,N);
        l2 = zeros(1,3,N);
        l3 = zeros(1,3,N);
        l4 = zeros(1,3,N);
        k1 = drdt_old;
        l1 = W(N,G,m,r_old);
        k2 = drdt_old + H*l1/2;
        l2 = W(N,G,m,r_old + H*k1/2);
        k3 = drdt_old + H*l2/2;
        l3 = W(N,G,m,r_old + H*k2/2);
        k4 = drdt_old + H*l3;
        l4 = W(N,G,m,r_old + H*k3/2);
        drdt_new = drdt_old + (H/6)*(l1 + 2*l2 + 2*l3 + l4);
        r_new = r_old + (H/6)*(k1 + 2*k2 + 2*k3 + k4);
    end
    for j = 1:N
        scatter(r_new(1,1,j)/AU,r_new(1,2,j)/AU,colourarray(j),'.')
    end
    pause(0.0000001)
    r_old = r_new;
    drdt_old = drdt_new;
end
Where W is the function for the acceleration:
Code:
 function [accel] = W(N,G,m,r)
 accel = zeros(1,3,N);
 for j = 1:N
     for i = 1:N
         if i ~= j
            accel(:,:,j) = accel(:,:,j) + G*m(i)*(r(:,:,i)-r(:,:,j))/norm(r(:,:,i)-r(:,:,j))^3;
         end
     end
 end
 end
Now here are the results. I have used Euler's method for these results but the RK4 results are pretty similar. RK4 is much more accurate than Euler integration but the error here is (I am pretty sure) not due to that. I have the Earth and Sun as the two bodies.
http://img15.imageshack.us/img15/5015/2bodyorbitzoomedout.jpg
The above image looks pretty good yeah? The Earth orbits the Sun in pretty much a circular orbit. Now, let's zoom in on the Sun. Remember that the Sun also orbits the centre of mass of the Sun/Earth system but it will remain very close to the centre of mass because the Sun/Earth mass ratio is so large. I don't know about you though, but this doesn't look right:
http://img171.imageshack.us/img171/3607/2bodyorbitzoomedin.jpg
I cannot explain this. Can someone please help? Just take the Euler integration...the code is so simple that I can't find the error. I have tried making the Sun body 1 and the Earth body 2, just in case I was referring to an index incorrectly or something but that did nothing.
I have not look closely at your code, but given the motion of the sun, I would guess what it would be. You are probably starting the Earth to the right of the sun causing the sun to be attracted slightly to the right. When the Earth is on the other side of the sun, it may well stop the motion of the sun to the right but that's all it does. You need to start the animation with the proper initial motion of the sun.
Hope this helps...
edguy99 is right, If you start the Earth moving at speed v, and the sun motionless, there is an initial momentum of [itex]m_{earth} v[/itex], which means you have a net drift of
the center of mass by
[tex]v \frac {m_{earth} } {m_{earth} + m_{sun}}[/tex]
The orbit of the Earth will drift as well, but the yearly drift is only
[tex]2 \pi r \frac { m_{earth} } {m_{earth} + m_{sun}}[/tex]
about (1/50000) AU
The graph produced for the sun is a cycloid, a superposition of a rotation round the center of mass and a linear motion with (nearly) the same speed. You get the same graph if you graph the position of a point on the circumference of a rolling wheel.
Thank you kindly for your response. After analysing it a bit more I see exactly what you are saying. There isn't an error in the code, aside from the initial conditions which shouldn't be exactly zero for the initial velocity of the Sun.
I have since tried some other examples too and have been able to replicate them (eg the figure 8 which is pretty cool).
