Super-fluid 4He - (two domains)
  • Context: Graduate
  • Thread starter Thread starter ibysaiyan
    domains
The discussion centers on the properties of superfluid helium-4 (4He), particularly the Lambda transition and the two-fluid model. The He II domain consists of a fraction of atoms in the same quantum state, acting as a single entity, while the remaining atoms exist in different quantum states, referred to as the normal fluid. As temperature approaches absolute zero, the proportion of normal fluid decreases. He II behaves similarly to a Bose-Einstein condensate (BEC) since all helium atoms can be described by a single wave function, indicating they occupy the ground state.
  • Understanding of quantum mechanics and Bose-Einstein statistics
  • Familiarity with superfluidity and the two-fluid model
  • Knowledge of the Lambda transition in low-temperature physics
  • Basic concepts of wave functions and quantum states
  • Research the two-fluid model for superfluids in detail
  • Study the properties and implications of the Lambda transition in superfluid helium
  • Explore the characteristics of Bose-Einstein condensates and their relation to superfluidity
  • Investigate the behavior of helium-4 at absolute zero temperature
Physicists, researchers in low-temperature physics, and students studying quantum mechanics and superfluidity will benefit from this discussion.
ibysaiyan
Hi PF ,
I am making a review article which is mainly based on low temperature physics , upon going through my search I have stumbled across the famous " Lambda transition" of super liquid helium. Paraphrasing what some of the books said : " In the He II domain a percentage of atoms in same quantum state act as a single entity , while the rest of the percentage is made up of atoms which have different quantum states ( another book says normal , what do they mean by normal ? vector [position ?] , the overall density stays constant " .
I need bit of a clarification on the bold bit , also it's said that as the temperature is dropped to absolute zero , the number of atoms ( normal) decreases.
I know that in Q.M particles are said to obey einstein-bose statistics if they have an integer spin of zero , so in what way is He II similar to Bose- Einstein condensate.
I appreciate your help.
-ibysaiyan
You need to check the two fluid model for superfluids. Here is one link I got from Google
http://www.yutopian.com/Yuan/TFM.html
Normal fluid represents the non-superfluid part. Nothing to do with vectors.
He-II is a BEC because all of the He atom are in the ground state and can be described by a single wave function.
  • · Replies 21 ·
9K
  • · Replies 25 ·
