Calculate Final Position of a Car Using Acceleration on a Level Road
The discussion revolves around calculating the final position of a car that undergoes different phases of acceleration and constant velocity on a level road. The problem involves analyzing the motion over specified time intervals with varying accelerations.
  • Participants discuss the use of a velocity-time graph to determine displacement and share their calculations for the final position. Questions arise regarding the accuracy of their results and the methods used to arrive at those values.
There is an ongoing exploration of different calculations and interpretations of the problem. Some participants have provided detailed breakdowns of their reasoning, while others question the assumptions made in their calculations. A few corrections to earlier calculations have been noted, but no consensus has been reached on the final position.
Participants are working under the constraints of the problem as presented, with specific time intervals and acceleration values. There is mention of discrepancies in calculated results, indicating potential misunderstandings or miscalculations in the approach taken.
chonkyfire
Starting from the origin, a car accelerates on a level road from rest at a(A)=-2.00 m/s^2 until T(1)=20.0s. The velocity is then held constant until T(2)=40.0s, and then the car accelerates at a(B)=5.00m/s^2 until T(3)=50.0s.
question: What is the final position of the car?
2. delta X
3. got -400m. but the answer should be -1350m.
Draw a v-t graph, area under the graph is the displacement.
But indeed I got -1337.5 m
chonkyfire said:
1.
2. delta X
20 seconds of acceleration achieves -40 m/s; so avergae vel -20.
-20 x 20 = -400 m while accelerating
A further 20 seconds at -40m/s covers a further -800m - that's -1200 so far.
We now accelerate at +5, so it takes 8 seconds to stop.
Average velosity -20, time 8 sec means a further -160m ; that's -1360m so far.
The acceleration continues for a further 2 seconds - reaching a velocity of +10 m/s.
Thats an averag of +5 m/s for 2 seconds, so a displacement of + 10m
-1360 + 10 = -1350
SO how did you get your -400 m ? [or -1337.5 for that matter]
Oh yes, should be -1350 m, cal a wrong time interval for deceleration...
  • · Replies 48 ·
10K
  • · Replies 20 ·
