Voltage to Voltage converter design
The discussion revolves around designing a voltage to voltage converter circuit that transforms DC voltages from +/-5V to +/-15V. Participants explore various design approaches, component suggestions, and considerations for current requirements and voltage regulation.
  • Homework-related
  • One participant requests a design for a voltage converter from +/-5V to +/-15V, seeking guidance on circuit options.
  • Another participant questions the clarity of the original request and asks for details about current requirements and the nature of the power supply.
  • A suggestion is made to use a single component DC-DC converter, although this is noted as potentially simplistic.
  • Multiple participants mention LM series DC-DC converter circuits, with one questioning the suitability of an 8.5 mA rating for a high-speed amplifier application.
  • Concerns are raised about the lack of specificity in the original request, including the need for floating outputs and voltage quality.
  • One participant suggests that an internet search for "charge pump" or "DC to DC converter" could yield useful resources.
  • A participant proposes considering a direct conversion from mains voltage to +/-15V DC instead of going through +/-5V DC.
  • Another participant inquires if the design should allow for adjustable outputs between 5V and 15V.
Participants express varying levels of understanding and clarity regarding the original request, with no consensus on the specific requirements for the voltage converter design. Multiple competing views and suggestions are presented without resolution.
Participants note the importance of specifying current requirements, voltage quality, and the nature of the output needed, which remain unresolved in the discussion.
mathish
Hi all,
I need a voltage to voltage converter design(circuit) from DC +/-5V to +/-15V
Thanks...
Thanks for letting us know.
(Was there a question?)
mathish said:
Hi all,
Hello mathish. I see you are new to physics forums. http://img96.imageshack.us/img96/4219/welcomelj.gif
Circuits to do this task can be complicated if you require heavy currents. What maximum current are you needing of each polarity? Do the voltages need to be regulated? What sort of supply do you have that provides the +5v and -5v?
Enjoy your time here on the forums. :wink:
The simplest design is to use a single component.
http://www.tracopower.com/products/dc-dc-converters/general-purpose/
But maybe that is considered cheating?
I had seen some LM series based dc -dc converter circuits for supply voltage of 70MHz high speed amplifier with the input current rating of 8.5 mA.is this suitable for this one ..If anybody know the answer for this one ..
Plz suggest for ur ideas...
What's the question?
You've not specified what you need it for, nor whether you're asking for directions to a suitable design, nor shown your own efforts to find such a design, nor have begun by discussing variations required for your particular application, which would require the following matters in any case;
a) if you are referring to +/- split supplies or whether you actually mean +DC/0
b) you've not specified the current requirement you need to meet
c) you've not qualified the voltage quality you need
d) you'e not specified if you need floating, or DC de-coupled, or other type of output
e) you've not even specified if the output can be 15VAC.
I'm not sure to what that "8.5mA" applies. 70MHz amplifiers are not rated at mA of input, and it would be an extremely low-powered dc-dc converter to be limited to loads not exceeding 8.5mA. Maybe you mean that the amplifier drew just 8.5mA average current from the supply?
But as you have not indicated what you need the dc-dc converter to do, no one here will be able to advise much.
A question well stated is half answered.
The folks aren't being mean, just they're puzzled.
Perhaps English is not your first language?
How much current do you seek ?
An internet search on "charge pump" will take you to numerous "how to do it" articles and suitable devices.
A google search on "DC to DC converter" will take you to many sites wanting to sell you one.
old jim
What drives your original dc voltage source? My guess is that it will be some kind of mains device, so instead of going 240 VAC to + /- 5 VDC to +/- 15 VDC go 240 VAC to +/- 15 VDC.
Are you looking for a tracking split power supply design with positive and negative outputs which can be adjusted between 5 volts and 15 volts?
Like this :
http://circuits.linear.com/537
http://circuits.linear.com/img/537_circuit_1.jpg
  • · Replies 16 ·
