Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Biology, Chemistry & Other Homework (http://www.physicsforums.com/forumdisplay.php?f=157)
-   -   Determining Initial and Equilibrium Concentration (Help ) (http://www.physicsforums.com/showthread.php?t=583120)
galaticman Mar2-12 01:17 AM
Determining Initial and Equilibrium Concentration (Help!!!)
You are given the equation Fe3+ + SCN- -> FeSCN-
You are performing an experiment in which you are mixing Fe(NO3)3 and NaSCN. A table is given and I will only list the first sets of data because if i can figure out the process for the first one I can figure out the rest. The table is:
10 mL of 2.0x10-3 M Fe(NO3)3
2mL of 2.0x10-3
Total Volume of Solution: 50mL
You are asked to to calculate the initial SCN- concentration (M) as well as the equilibrium FeNCS2+ concentration (M)
I am just not sure how to go about doing that. Any help would be greatly appreciated!!!!!
NOTE: It also mentions that to assume all of the SCN- is present as FeNCS2+ but I am pretty sure that this is irrelevant and is relevant to the later part of the lab
Borek Mar2-12 02:48 AM
Re: Determining Initial and Equilibrium Concentration (Help!!!)
So, if I understand you correctly, you take 2 mL of 2x10-3M solution of SCN-, and you dilute it up to 50 mL (other solution doesn't matter at this moment)?
How many moles of SCN- in these 2 mL? What is the concentration of the solution containing this amount of SCN- in a 50 mL volume?
galaticman Mar2-12 03:26 AM
Yup that is pretty much it except it is not just SCN it is NaSCN but Im not sure if that matters for the problem or not?
Borek Mar2-12 04:19 AM
It doesn't matter - if the solution is 2x10-3 M in NaSCN, it is also 2x10-3 M in Na+ and SCN-.
galaticman Mar2-12 12:01 PM
Ohhhh okay I got it then! Thanks!!!!!
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
