HELP determine work needed to push a crate up a ramp at constant speed
The problem involves determining the work required to push a crate up a ramp, given specific dimensions and mass. The context is within the subject area of physics, specifically focusing on concepts of work, energy, and forces in mechanics.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to calculate work using the formula for gravitational force but expresses uncertainty about the correctness of their answer. Participants question the understanding of the relationship between force and energy, and the distinction between work and force is discussed.
The discussion is ongoing, with participants providing feedback on the original poster's reasoning. Some guidance is offered regarding the need to relate work to potential energy, but no consensus on the correct answer has been reached.
There is an indication that the original poster may lack clarity on fundamental concepts, such as the difference between force and energy, which could affect their approach to the problem.
dani123
A ramp leading up to a loading platform is 3 m long and 1 m high at its highest point. If the friction is ignored, what work is needed to slide a 600-kg crate up the ramp at a constant speed?
a) 2.00 *10^2 J
b) 5.89 *10^2 J
c) 1.80 *10^3 J
d) 5.88 *10^3 J
I believe the answer is d) but I would just like someone to explain the answer to me and correct me if d) isn't the answer. THANK YOU SO MUCH, in advance :)
a=0
Fnet=0... because its at a constant speed
W=Ffriction=mg
W=600kg*9.8m/s^2= 5.88*10^3J
hi dani123! :smile:
(try using the X2 button just above the Reply box :wink:)
correct :smile:
W=Ffriction=mg
wrong, W is work, that's completely different from force
work done equals the change in energy, so you need an equation relating W and potential energy
maybe it's right, maybe it isn't, but the reasoning is certainly wrong :wink:
Ok so this may be a stupid question but is there a difference between force and energy? If so how am I suppose to calculate the energy in order to get the work required to push the crate up the ramp! Thanks so much for your time
erm … yeeees! :smile:
big difference
energy = work = force times distance
(for example, mg is force, mgh is energy)
you need to go back to your book, and read those chapters again, before trying any more of these questions! :wink:
ops! lol its been a long day haha thank you
11K
  • · Replies 29 ·
  • · Replies 56 ·
