Complex integral over a circle
The discussion revolves around evaluating a complex integral over a circle, specifically the integral of the function \( \frac{ze^z}{2z-3} \) along the contour defined by \( |z| = 2 \). Participants explore the application of the Cauchy Integral Theorem and the conditions under which a function is considered analytic.
  • Mixed
  • Participants discuss the conditions for applying the Cauchy Integral Theorem, including the concept of analyticity and the implications of poles within the contour of integration. There are attempts to clarify the relationship between the function's behavior at poles and the evaluation of the integral.
The discussion is ongoing, with participants sharing their understanding of the Cauchy Integral Theorem and its application to the problem. Some express confusion regarding the definitions and implications of analyticity, while others provide insights and corrections to misconceptions. There is no explicit consensus, but several productive lines of reasoning are being explored.
Participants mention challenges in visualizing complex integrals and the need for clearer understanding of the Cauchy Integral Theorem. There are references to specific mathematical concepts and theorems, indicating a focus on foundational understanding in complex analysis.
undergradphys
1. let C be the circle |z| = 2 traveled once in the positive sense. Computer the following integrals...
a.∫c zez/(2z-3) dz
I am confused as to a step in my solution, but i believe a relevant equation is if i am integrating over a circle and the function is analytic at a point, i can remove it by integrating and removing the denominator and replacing it with 2pi*i in the numerator. However i do not know why. This seems to be a product of the cauchy reimann equations used to calculate the integral.
So i need to get the equation in the form x/z-z0 so i divide everything by 2.
I am left with .5*zez/(z-(2/3)) In this form i can see it is analytic at z=3/2 (i believe the word analytic to mean that it goes to infinity)
so i remove the denominator, and replace it with a substitution of 2pi*i...
2pi*i*.5*z*ez evaluated at z=3/2
is equal to 3/2pi*i*e3/2
Correct? i Know that sometimes the factor 2pi*i can be negative but i don't understandw hy..
Okay so i have looked abck and tried to understand the derivation again, and have realized it comes as a consquence of the equation integral of f(z)/(z-z0)^m dz is equal to 2pi*i f^(m-1) (z0) / (m-1)!
(if anyone finds my notation to be confusing or sloppy, i can rewrite it. also is there a link to a website that i can use to link equations to those neat pictures? it seems a lot easier to understand than what I am doing)
so to apply that equation to the above, my function is .5*ze^z, my Z0 is 3/2, and i rewrite my equation
(2pi*i*(.5ze^z)^0)/0!
where i know 0!=1, and anything raised to the 0 equals 1, so
my integral evaluates to 2pi*i.
You were closer the first time. It's the Cauchy Integral Theorem you want to look at. And 'analytic' doesn't mean 'goes to infinity', it means rather the opposite. I think you might want to read up on this before you tackle the problem. Your concepts are very confused.
Okay so third times a charm, i figured out that it is not f^(m-1), but f with derivatives equal to m-1.
So since my m=1 for this, i do not have to take a derivative but only evaluate it at 3/2 over !0.
so my answer is pi * i * 3/2 * e^(3/2)
I know, i am struggling in this class and I am trying to keep up with it. I am going to re-read the chapter in order to understand the cauchy integral theorem but to be honest I am pretty poor at learning math out of books. I am best at visualizing problems which is particularly difficult in complex equations since its a 4 dimensional problem.
There's less detailed visualization required here than you might think. Your answer in the last post is correct. But I'd feel better if you were clearer on why that is.
Okay so an integral is analytic if it satisfied the cauchy reimann equations. Basically what i know is if an equation satisfies the cauchy reimann equations, all is good and it can be worked with. I need to solve the second order cauchy reimann equation in order to prove a function is harmonic. Proving a function is harmonic is important (im a physics major) but i havn't had to do more than prove this.
Anyhoo a function is analytic if the power series converges. (i see what you mean, analytic is good, not bad) So where the denominator "blows up" (when z=z0) is where we evaluate the integral around because we are really evaluating the power series there?
If a function has a z0 outside the integral would the function then equal 0?
You are getting there. Your function has pole at z=3/2 and that's inside of the circle |z|=2. Just apply the Cauchy Integral Theorem.
To be honest i can do the problems but the cauchy integral theorem still perplexes me. I understand the integral fails if there is a "hole" within the integral, and equals 0 everywhere else. So i guess what I am really trying to integrate is the pole? So the entire point is to find the integral of the pole?
I found this extremely helpful:
http://mathworld.wolfram.com/CauchyIntegralFormula.html
But what confused me was that when winding multiple times over the integral the equation becomes 1/2pi*i, which seems counter intuitive to me since if the first integral is equal to 2pi*i, if i integrate twice it should simply be 4pi*i.
The "derivative of f" was expressed as 1/(2pi*i)*(f(zo)/(z-zo)^2, but i thought i could just take the derivative of a complex number as i did a "regular" number...
I also have another problem related to this, Should i create another thread? (i am going to sleep for now so ill post it here, as i suspect the answer is i shouldnt)
1. let C be the square with vertices z= +-2 and +-2i traversed once in the positive sense.
etc etc etc.
i suspect i evaluate these just as i would the first problem. As from how i understand the integral as long as the pole is within the "area" I am just going to be integrating it anyway, so i can effectively ignore the area that I am supposedly integrating and just treat it as though I am integrating the pole. The area as far as i know is just to stipulate if the pole is within it or not.
etc etc etc.
You aren't 'integrating the pole' you are integrating the function along the contour. In some cases you can do that directly. You should work out integral of f(z)dz around the contour |z|=1 for some simple functions, like f(z)=1/z, f(z)=1, f(z)=z. You can do this with the change of variable z=exp(it). Notice that the only integral of these that is nonzero has a pole at z=0. Finding contour integrals if the function or contours are more complicated would be extremely hard. But luckily you have these theorems that relate the hard job of finding the integral to the much easier job of finding and summing the residues of the poles. That's the general idea.
