Random Variables: Calculating E[X|Y]
The discussion revolves around calculating the conditional expectation E[X|Y] in the context of random variables. The original poster expresses confusion regarding the relationship between X and Y, particularly how to compute E[X|Y] given the provided information and equations.
  • Participants explore the definition of E[X|Y] and its implications, questioning how Y influences X and the nature of their dependency. There are discussions about the conditional probability density function and its normalization. Some participants also raise concerns about the interpretation of biconditional relationships and the values of the probability functions involved.
The conversation is ongoing, with participants providing clarifications and attempting to rationalize the calculations involved. There is a mix of interpretations being explored, particularly regarding the conditional expectations for different values of Y. Some guidance has been offered on deriving the conditional pdf and its application in calculating E[X|Y].
Participants note the complexity of the problem due to the relationships between the random variables and the assumptions about their distributions. There is an acknowledgment of the need for further clarification on the conditional relationships and the definitions being used.
Joshuarr
This is an example in a textbook; it already has the solution. I don't understand how E[X|Y] was obtained though. So my question is how do I calculate E[X|Y] from the information given?
http://img689.imageshack.us/img689/484/20120413134552578.jpg
http://img27.imageshack.us/img27/770/20120413134653906.jpg
This last part is probably not needed to solve the problem, I think. But I am adding it for completeness and context.
http://img801.imageshack.us/img801/3802/20120413141622958.jpg
E[X] is the expected value, or mean, of X.
[tex]E[X|Y] = \int_{-\infty}^{\infty} x f_{X|Y}(x|y)dx[/tex]
Law of Total Variance: var(X) = E[var(X|Y)] + var(E[X|Y])
I don't really understand how X is dependent on Y. It seems to me that Y is dependent on X! I'm really lost with this material, though. I don't have fX|Y(x|y) and I think that E[X|Y] is independent of Y, which would imply that E[X|Y] = E[X].
[tex]E[X] = 1/2\int_{0}^{1} x dx + 1/4\int_{1}^{3} x dx <br /> = 1/2*1 + 1/4*2 = 1?[/tex]
E[X|Y] is supposed to be a random variable that is a function of Y though. I just don't see how Y plays any part in the computation.
Just forget about the integrals and junk and just think about what that is telling you to do.
E[X|Y=y] says what is the expected value of the variable X given we know Y is a certain value. So, Y can take on 2 values -- 1 and 2. Let's write these out:
E[X|Y = 1] and E[X|Y = 2]
So what do we know about X if we know Y = 1? We know, by the definition of Y, that X < 1. So the conditional pdf of X is the region between 0 and 1 normalized such that the area from 0 to 1 equals 1.Like this:
[tex]f_{X|Y=1}(x) = \frac{f_X(x)}{p[Y=1]}[/tex]
where f_x(x) is only nonzero where y = 1 (meaning x < 1)
[tex]f_{X|Y=1}(x) = \frac{f_X(x)}{\int\limits_{0}^{1} f_X(x)dx}=\frac{f_X(x)}{\frac{1}{2}}=2f_X(x)[/tex]
Once we have this conditional pdf, just plug it into the integral definition of expectation
[tex]\int\limits_{0}^{1} 2xf_X(x) dx[/tex]
Note, again, the limits here are because this f_X(x) (it is bad notation, I know) is actually nonzero only where x < 1 since it comes from finding the P[X <= x AND Y = y] in the equation
[tex]P[X \le x | Y = y] = \frac{P[X \le x \cap Y = y]}{P[Y=y]}[/tex]
For the other one, it's the exact same except we know x is greater than or equal to 1.
Thanks for answering.
Can we always assume the if is biconditional (if and only if)? It seems that you interpret IF x <1, then Y=1 to also mean, IF Y =1, then x <1.
I'm also not sure why [tex]f_{X|Y=1}(x) = 2*f_X(x) = 1[/tex] I think this is the probability for E[X|Y=1], isn't it supposed to be 1/2?
I assumed that f_X(x) = 1/2, since that's its value between 0 and 1.
There is no interpretation. If someone tells you the only way you can make Y = 1 is for X < 1 and they also tell you Y = 1, you know X < 1.
I derived for you the conditional pdf. The conditional expectation is found through weighted integration of the conditional pdf:
[tex]E\{X|Y=1\}=\int\limits_{0}^{1} 2xf_X(x) dx =\int\limits_{0}^{1} 2x\frac{1}{2} dx=\int\limits_{0}^{1} x dx=\frac{1}{2}[/tex]
But of course, you can just use the common sense notion of expectation to figure it out. The first one is uniform from 0 to 1, so its average value is 1/2. The second is uniform from 1 to 3, so its average value is 2.
I really appreciate your clarification. The problem that I was having was rationalizing how the probability of E[X|Y=1] and E[X|Y=2] is 1/2, but I think I understand now.
Thank you!
  • · Replies 18 ·
