Converting Methane to Methanol with Photochemical Reactor
  • Thread starter Thread starter Skylight100
    Methane Methanol
The discussion centers on the conversion of methane to methanol using a photochemical reactor, as detailed in a Department of Energy report. Key points include the role of tungsten oxide as a catalyst, which, while not consumed in the reaction, may require regeneration due to deactivation phenomena such as coking. Additionally, the nitrogen used for cooling the UV lamp is likely a consumable in laboratory settings, while commercial applications would utilize a closed-loop system. The report also suggests the feasibility of using visible light for methane conversion, which could simplify reactor construction.
  • Understanding of photochemical reactors
  • Knowledge of catalyst behavior, specifically tungsten oxide
  • Familiarity with nitrogen cooling systems
  • Basic principles of methane conversion processes
  • Research tungsten oxide catalyst regeneration techniques
  • Explore the design of closed-loop nitrogen cooling systems
  • Investigate the use of visible light in photochemical reactions
  • Study the effects of coking and fouling on catalyst performance
Chemists, chemical engineers, and researchers involved in renewable energy and catalysis, particularly those focused on methane conversion technologies.
Skylight100
Methane to Methanol
Methane to Methanol 2
Hello everyone. In the link above is a pdf from the Department of Energy detailing how they created methanol our of water using a photochemical reactor.
Im not sure if I am asking the correct people (you people) but I was wondering if you people could help me as Chemistry is not my forte.
I therefore have a few questions Id like to ask...
1. is the tungsten oxide catalyst a static/permanent feature in its capacity as a catalyst inside the reactor or is it a consumable which needs perpetual replenishing? If it is not, is there a method where after the process has finished you can salvage or capture the tungsten catalyst from the solution?
2. is the nitrogen used to cool the UV lamp built within a closed loop as a coolant inside the reactor or is it a consumable which needs perpetual replenishing?
3. The report suggests that visible light is possible over UV lamp to use for methane conversion for practical considerations for quartz reactor construction. Is this correct?
Thanks for any feedback given
Chemistry news on Phys.org
By definition catalyst is not consumed in the reaction. Doesn't mean it lasts forever.
These articles were very useful to me, thanks for posting.
Guy above me is right, catalysts are never consumed by a reaction. But certain phenomena like coking, fouling, or deactivation can make a catalyst unusable and necessitate regeneration or replacement. In this article, it looks like the catalyst is used constantly without being replaced. If deactivation of the catalyst was observed, they should have reported that.
The nitrogen to cool the lamp is probably just a nitrogen stream that they release to the atmosphere because they're in a lab and N2 is cheap. In a commercial process, the cooling medium would probably be in a loop as you suggested. So the N2 must be constantly replenished.
  • · Replies 19 ·
  • · Replies 19 ·
11K
  • · Replies 59 ·
13K
11K
