Turning cooking gas into butter
The discussion revolves around the feasibility of transforming butane, a component of cooking gas, into butter through a series of chemical reactions. Participants explore the theoretical and practical aspects of this idea, including the chemical processes involved and the potential for educational demonstrations in a chemistry context.
  • Experimental/applied
  • One participant proposes a sequence of reactions: butane to n-butanol to butyraldehyde to butyric acid, suggesting a transformation from a colorless gas to a solid resembling butter.
  • Another participant challenges the idea, noting that butyric acid is far from butter and has an unpleasant smell, indicating the need for further conversion to triglycerides.
  • Concerns are raised about the complexity and cost of the required chemical processes, with estimates suggesting that starting with pure materials and using specialized equipment could be very expensive.
  • One participant suggests that using butane directly might be more practical than attempting to isolate other compounds, while also questioning the use of halogens and sulfuric acid as alternatives.
  • Participants express varying degrees of enthusiasm for the educational potential of the experiment, even if the end product is not actual butter.
There is no consensus on the feasibility or practicality of the proposed chemical transformations. Participants express differing views on the complexity, cost, and educational value of the experiment.
Participants mention the need for fractional distillation and high-pressure reactions, highlighting the technical challenges and safety considerations involved in the proposed processes. The discussion reflects uncertainty regarding the specific chemical pathways and their viability.
This discussion may be of interest to students, educators, and hobbyists in chemistry, particularly those exploring experimental demonstrations or the practical applications of chemical transformations.
Weissritter
O hai, Physics Forums.
I've came up with an idea, an amazing experiments which turns an invisible gas into butter. It may not be cheap, but could be a great way to motivate students into chemistry.
Putting some pieces together in Chemistry class the idea jumped in. My main language is not English, so I made a drawing of the transformation of the buthane troughout the experiment. (I have no idea what the names of the compunds are in English).
I've been told it is possible, not exactly with these compounds, but it is supposed to be possible.
So, I need someone to tell me how, or at least if it can be done.
I hope I don't mess up with any dangerous chemical in the list of prohibition of the forum.
Edit: link deleted, if you want to discuss it here, post it here.
Chemistry news on Phys.org
I'm not going there! Why can't you just copy the pertinent information here so we can discuss it?
Fine...this is the idea:
You have buthane->n-Butanol->Butyraldehyde->Butyric acid
Which means: Colorless gas->butter magically appearing in a glass.
Butyric acid is soooo far away from butter! It smells like baby vomit left in a hot car for three days. You need to consider converting the free acid into the triglyceride. Hint: you will need to find a way to produce glycerin as well.
So, according to your statement, my whole life is a lie, but I'd get into it sooner or later.
But well, as an experiment, it would be enough to convince people not to let down Chemistry, which was my starting objective.
So, a colorless gas-> a white bad smelling solid, but they don't need to know it's smell, not right there, at least.
So, are those reactions hard or costful?
Not too bad. Propane to propene to allyl chloride to epichlorohydrin to glycerine. There is a very simple way to produce better butter that will always be cheaper, though.
Even if smelly, butyric acid means a successful experiment, as this' one objective is to amaze students. I won't be making butter out of it, and yes, it will be pretty expensive than buying butter or butyiric acidm but the objective is to amaze people into chemistry.
So, are those reactions how much costful?
Carolie04 said:
http://www.heritems.info/avatar2.jpg You have buthane->n-Butanol->Butyraldehyde->Butyric acid
I see you're getting it, now, how can I make those reactions occur?
The problem is that you must work with 'cooking gas'. It's likely to be a mixture of compounds like methane, ethane, propane, butane, isobutane, pentane, isopentane and so forth. To make a pure product you must start with pure starting materials. That's your first step will be a fractional distillation to isolate ethane or n-butane. That kind of procedure requires expensive equipment. The next step will be a high pressure, high temperature dehydrogenation over a special catalyst to make either ethylene or 1-butene or 2-butene. The ethylene will need to be purified by distillation as will the 1-butene/2-butene. If you start with ethylene, it will need to be dimerized to produce 1-butene (which will need to be purified by distillation). All of these steps are performed in gas phase and require very specialized equipment like high pressure metal reactors, tubing, compressors, distillation towers, a refrigeration plant, etc... You might be able to get started for perhaps $150K... triple that if you include proper safety gear and permits. Then the "easy" chemistry begins.
You say you're doing this as a demonstration for school kids?
Oh, man, my eyes hurt. 450K is way much, so... buying butane and using it as base chemical would be the way. Using halogens and sulfuric acid wouldn't be a cheaper way?
For your last question, well, doing this is an amazing experiment, which could work for children or teenagers with little previous interest in chemistry.
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 19 ·
11K
  • · Replies 21 ·
