How to find the time of two object passing each at opposite direction.
  • Thread starter Thread starter louis676
    Direction Time
The problem involves two objects: a ball dropped from a height of 79 m and another ball thrown upward from the ground at a velocity of 28 m/s. The objective is to determine the time it takes for both balls to reach the same height.
  • Exploratory, Mathematical reasoning
  • The original poster outlines their calculations for the positions of both balls over time and attempts to equate the two equations to find the time of intersection. Some participants suggest maintaining more decimal places for accuracy in verification.
The discussion includes confirmations of the original poster's approach, with some participants expressing agreement on the calculated time of 2.8 seconds. However, there is no explicit consensus on the correctness of the final answer, as some participants seek further validation.
Participants question the precision of the calculations and the implications of rounding in the context of the problem. There is an emphasis on checking the results against each other to ensure consistency.
louis676
1. A ball is dropped from a height of 79 m. Simultaneously a ball is thrown upward from the ground at a velocity of 28 m/s. How much time passes until the balls are at the same height.
I need someone to check if my approach is correct.
Position of falling object
x =?
Δt =?
Xo = 79 m
Vo = 0 m/s
A = -9.8 m/s 2
X = Xo + Vo Δt + .5a (Δt) 2
X = 79 m + 0m/s (Δt) + .5(-9.8 m/s 2) (Δt) 2
X = 79 m - 4.9 m/s 2(Δt) 2Position of elevating object
x =?
Δt =?
Xo = 0 m
Vo = 28 m/s
A = -9.8 m/s 2
X (Δt) = 0m + 28m/s Δt + .5a (Δt) 2
X (Δt) = 28 m/s (Δt) + .5(-9.8 m/s 2) (Δt) 2
X (Δt) = 28 m/s (Δt) – 4.9 m/s 2 (Δt) 2
To find the time, we need to set both the equation equal to each other.
79 m – 4.9 m/s 2 (Δt) 2 = 28 m/s (Δt) - 4.9 m/s 2(Δt) 2
79m = 28 m/s (Δt)
2.8 s = Δt
Then I replace 2.8 for t in both of the equation and check if my time is correct
X = 79 m – 4.9 m/s 2 (Δt)2
X = 79 m – 4.9 m/s 2 (2.8 s)2
X = 79 m - 4.9 m/s 2 (7.84s 2)
X = 79 m - 38.416 m
X = 40.6 m
X = 28 m/s (Δt) – 4.9 m/s 2 (Δt) 2
X = 28 m/s (2.8s) - 4.9 m/s 2 (2.8 s)2
X = 78.4 m - 38.416 m
X = 40 m
The answer is approximately the same.
Your approach is fine, and the result of 2.8s is good (at least to one decimal).
Keeping a few more decimal places in intermediate results would make your check of the answer more convincing :wink:
So my answer is correct, right?
I believe that is what I stated...
Alrite thank you so much.
No problem. Cheers :smile:
  • · Replies 38 ·
10K
  • · Replies 36 ·
