Why the K.E. Increases in a 10-Stage Linac Accelerator with 200 kV Supply
  • Context: Graduate
  • Thread starter Thread starter jsmith613
    Drift Tube
The discussion revolves around the kinetic energy (K.E.) of electrons in a 10-stage linac accelerator powered by a 200 kV supply. Participants explore the relationship between the accelerating potential difference and the resulting kinetic energy of electrons as they move through different stages of the accelerator, including calculations and theoretical considerations.
  • One participant notes that the K.E. at stage 2 is twice that of stage 1, prompting questions about the underlying reasons for this increase.
  • Another participant poses a question about the kinetic energy of an electron accelerated through two successive potential differences of 300V, asking if the new K.E. would simply double, and seeks clarification on the correct calculation.
  • Further elaboration includes the use of electron-volt (eV) units for calculations, with detailed expressions for kinetic energy and relationships between velocity and mass.
  • Participants discuss the shielding effect of drift tubes on electrons and the necessity of alternating current (AC) voltage to ensure proper acceleration.
  • One participant summarizes the kinetic energy changes between stages, suggesting a pattern of doubling and multiplying by 1.5 for subsequent stages, while expressing gratitude for the insights gained.
There is no clear consensus on the exact relationship between kinetic energy and potential difference across the stages, as participants raise different questions and calculations without resolving the underlying uncertainties.
Participants rely on specific assumptions regarding non-relativistic effects and the behavior of electrons in drift tubes, which may not be universally applicable. The discussion includes various mathematical expressions and relationships that are not fully resolved.
jsmith613
Lets say we had a 10-stage linac accelerator and we were using a 200 kV supply.
Apparently the K.E at stage 2 (in the second tube) is twice that of the first tube (stage 1).
why is this?
In fact a better question is:
If an electron, starting at 0 m/s is accelerated across a p.d of 300V its new KE is
4.8 * 10-17J (E = QV).
My question is, if I accelerate this electron (with this KE) through another p.d of 300V then, disregarding relativistic effects, will the new KE be
4.8 * 10-17J *2 = 9.6*10-17J ?If not then what will it be?
It is easier to do the calculations using eV (electron-volt) units. The electron mass in eV units is mc2 = 511,000 eV. The kinetic energy is
[tex]KE=\frac{1}{2}mv^2=\frac{1}{2}\beta^2mc^2[/tex]
where v=βc and c = 3 x 108 meters per second. So
[tex]\beta=\sqrt{\frac{2\cdot KE}{mc^2}}[/tex]
So β = 0.03427, 0.04846, 0.05935, etc. for n=1, 2, 3, etc. and KE =n·300 eV.
When the electron is inside a drift tube, it is completely shielded from the applied voltage. You have to use an ac voltage and a drift tube so that when the applied voltage is the wrong polarity, the drift tube shields the electron, and the electron only "sees" the correct polarity voltage.
[added] If you use an ac frequency of f = 100 MHz, the drift tube lengths are [itex]L=\frac{\beta c}{2f}=[/itex] 0.05141, 0.07269, .08903 meters etc.
OK so a good way to see it is as follows:
tube 1 --> tube 2 - KE doubles
tube 2 --> tube 3 - KE * 1.5
so
Tube 1 = L
tube 2 = L*sqrt(2) = L-new
tube 3 = L-new * sqrt(1.5)
but this has answered by question so thanks a lot :)
  • · Replies 24 ·
