Projectile Motion of Basketball Shot to Ring
The discussion focuses on calculating the horizontal displacement of a basketball shot from a height of 2.8 meters to a ring at 3.3 meters. The basketball is released with a velocity of 5.5 m/s at an angle of 54 degrees. The initial vertical velocity is determined to be 4.45 m/s, while the horizontal velocity is calculated at 3.23 m/s. The challenge lies in determining the time of flight, as the projectile does not start and end at the same height.
  • Understanding of projectile motion principles
  • Ability to calculate initial vertical and horizontal velocities
  • Familiarity with kinematic equations
  • Knowledge of trigonometric functions for angle calculations
  • Calculate the time of flight using the vertical motion equations
  • Explore the use of kinematic equations for non-level projectile motion
  • Learn about the impact of initial height on projectile trajectories
  • Investigate the effects of different launch angles on horizontal displacement
Students studying physics, particularly those focusing on mechanics and projectile motion, as well as educators looking for practical examples of kinematic equations in action.
Chooks
A basketball is thrown from a height of 2.8m above the ground and goes through a basketball ring that is 3.3m above the ground. If the release velocity was 5.5 m/s at an angle of 54 degrees upwards from the horizontal, calculate the horizontal displacement the ball will travel between being released and reaching the ring
I know I have to find initial vertical and horizontal velocity and time
I have found initial vertical velocity of 4.45m/s and horizontal velocity to be 3.23m/s
I don't know where to start with time as i have only ever done projectiles that take-off and land at the same height ?
For any vertical or horizontal displacement, the time taken are equal.
  • · Replies 18 ·
28K
