Calculate relativistic com frame for two particles?
The discussion revolves around calculating the center of mass (com) frame velocity for two particles moving at arbitrary velocities in the lab frame. Participants explore various methods and concepts related to relativistic momentum and energy, as well as the implications of particle disintegration and conservation laws.
  • One participant asks for a standard method to calculate the com frame velocity for two particles, noting its absence in common texts like Goldstein's.
  • Another participant presents the relationship between energy and momentum, suggesting that the velocity of an equivalent particle can be derived from these quantities.
  • It is proposed that the total momentum in the com frame can be zero, leading to a more rigorous calculation using Lorentz transformations.
  • Several participants agree on the calculation of total momentum and energy as a basis for determining the com frame velocity.
  • Visualizing the disintegration of a particle into two others is highlighted as a key insight, emphasizing the elegance of the result related to 4-momentum conservation.
  • Discussion includes a reference to a document that contains formalism relevant to invariant mass during particle disintegration.
  • One participant questions what determines the final state of the system of equations, suggesting a probabilistic nature influenced by matrix elements.
  • A philosophical angle is introduced regarding the intersection of deterministic measurement and probabilistic outcomes in physics.
Participants express various viewpoints on the methods for calculating the com frame velocity, with some proposing specific mathematical approaches while others explore conceptual implications. The discussion remains unresolved regarding the exact methods and interpretations of the final state in particle interactions.
There are limitations in the discussion, including assumptions about the definitions of momentum and energy in different frames, and the unresolved nature of certain mathematical steps related to the calculations presented.
jason12345
Does anyone know of a standard way of calculating the com frame velocity for two particles moving at arbitary velocities in the lab frame?
It's strange that this standard result isn't even in Goldstein's et al book
E2 - p2 = m2
βγ = p/m.
The velocity of a single particle in terms of its energy and momentum is given by
$$\beta = \frac {pc}{E}$$
Given this, what would you expect the velocity of the "equivalent particle" representing the motion of a system of two particles to be? Or indeed, any number of particles?
You can get the result a bit more rigorously by using the Lorentz transformation for energy and momentum
$$p^{\prime} c = \gamma (pc - \beta E)$$
and requiring that the total momentum in the primed frame be zero, i.e. for a system of two particles ##p_1^{\prime} c + p_2^{\prime} c = 0##.
Calulate [tex]{\bf P=p_1+p_2)}[/tex], and [tex]E=E_1+E_2[/tex].
Then [tex]{\bf V=P}/E.[/tex].
@itbell and Meir Achz, yes I see what you mean!
The key for me was visualising the disintegration of a particle into p1 and p2, while using conserving 4-momentum.
This really is a very elegant, beautiful result, which I can't find anywhere in my copy of Goldstein, 3rd edition, nor in any of the problems. Maybe it's mentioned in books devoted to the dynamics of particle collisions.
For c=1, but in general [tex]{\bf V=P}c^2/E.[/tex]
yes?
Much of the formalism, including the concept of invariant mass during particle disintegration, is included here:
http://pdg.lbl.gov/2010/reviews/rpp2010-rev-kinematics.pdf
yes?
I use light years.
So in Fig 39.3 it shows the constraints of the final state.
What determines in what final state the system of equations will stabilize?
The final state is located randomly somewhere inside the shaded area, with a probability distribution that is determined by the matrix element for the process that we're dealing with.
It's rather like asking "what determines exactly when a particular radioactive nucleus will decay?"
So this is where deterministic measurement meets the road to philosophical physics.
This is where "squeezing" occurs?
  • · Replies 0 ·
  • · Replies 20 ·
  • · Replies 0 ·
