Conservation of Angular Kinetic Energy
The discussion centers on the conservation of kinetic energy in a collision problem involving a 2 kg disk and a 1 kg stick on frictionless ice. The equation derived for kinetic energy conservation is 1/2 * m_d * v_{d i}^2 = 1/2 * m_d * v_{d f}^2 + 1/2 * m_s * v_{s}^2 + 1/2 * I * \omega^2. The confusion arises regarding the rotational kinetic energy of the disk, which is clarified by noting that the problem does not specify the disk is rotating, indicating it is sliding without rotation. Thus, only translational kinetic energy is relevant in this scenario.
  • Understanding of elastic collisions and conservation of energy principles
  • Familiarity with moment of inertia calculations
  • Knowledge of translational versus rotational motion
  • Basic physics of rigid body dynamics
  • Study the principles of elastic collisions in detail
  • Learn about moment of inertia for various shapes and their applications
  • Explore the differences between translational and rotational kinetic energy
  • Investigate real-world applications of kinetic energy conservation in sports physics
Physics students, educators, and anyone interested in understanding the dynamics of collisions and energy conservation in mechanical systems.
roam
I have some difficulty understanding how they have obtained the equation for conservation of kinetic energy in the following solved problem:
There is a 2 kg disk traveling at 3.0 m/s strikes a 1.0 kg stick of length 4.0 m that is lying flat on nearly frictionless ice. The disk strikes the endpoint of the stick, at a distance r = 2.0 m from the stick's center. Suppose the collision is elastic and the disk does not deviate from its original line of motion. The moment of inertia of the stick about its center of mass is 1.33 kg.m2. If we apply the conservation of kinetic energy to the system we get:
[itex]\frac{1}{2}m_d v_{d i}^2 = \frac{1}{2}m_d v_{d f}^2 + \frac{1}{2}m_s v_{s}^2 + \frac{1}{2} I \omega^2[/itex]
[itex]\frac{1}{2} (2)(3)^2 = \frac{1}{2}(2) v_{d f}^2 + \frac{1}{2}(1) v_{s}^2 + \frac{1}{2} (1.33) \omega^2[/itex]
Here is a diagram:
http://desmond.imageshack.us/Himg818/scaled.php?server=818&filename=prob1r.jpg&res=landing
I'm confused because the only rotational kinetic energy considered was the rotational kinetic energy of the stick after the collision. But the disk has a rotational kinetic energy too both before and after the collision, right? :confused:
Shouldn't we model the motion of the rolling disk as a combination of both translation and rotation? If so this is what we would get:
[itex]\frac{1}{2}m_d v_{d i}^2 + \frac{1}{2}I_{d} \omega_{d, i} = \frac{1}{2}m_d v_{d f}^2 + \frac{1}{2}m_s v_{s}^2 + \frac{1}{2} I_s \omega_{s}^2 + \frac{1}{2}I_{d} \omega_{d, f}[/itex]
So, why have they ignored the rotational kinetic energy of the disk? Any help is greatly appreciated.
I think the answer is simply that your assumption that the disc is rolling is wrong. It does not say anywhere in the problem that the disc is rotating. It's probably just sliding across the surface of the ice like a hockey puck. Therefore, it has only translational kinetic energy.
A simple advice in problems like these - Since the radius of disc was not given, it was not possible to determine the Moment of Inertia of the disc about its centre, so it was safe to assume that we need not consider its angular kinetic energy as far as this problem goes.
  • · Replies 33 ·
