Force and Electric field within a cubic lattice
The discussion revolves around a problem involving Cl+ ions positioned at the corners of a cubic lattice with a Cs- ion at the center. Participants are exploring the net force on the Cs- ion, the electric field generated by the Cl+ ions, and the electric potential at the center of the cube.
  • Some participants suggest that the net force on the Cs- ion might be zero due to symmetry, questioning if this reasoning is valid. Others express uncertainty regarding the electric field and potential, considering the implications of symmetry and the nature of electric fields and potentials.
Participants are actively discussing the implications of symmetry on the net force and electric field. Some guidance has been offered regarding the calculation of electric potential, with suggestions to consider the contributions from individual charges rather than relying solely on integrals.
There are mentions of potential confusion regarding the nature of the charges, with a side note about the assignment of negative charges to chlorine ions. The discussion also touches on the complexity of integrating to find electric potential, with some participants expressing that it may be unnecessary in this context.
VictorWutang
There are Cl+ ions at the corners of a cube of side a = .4nm and a Cs- ion at the center.
a) What is the net force on the Cs- ion?
b) What is the electric field at the center of the cube cause by all of the Cl ions?
c) What is the electric potential at that point?
F = kq1q2 / r2
E = kq / r
U
a) Since each force has an equal force from the opposite corner, I think the net force should be 0. (seems too easy for a test problem, so please let me know if I'm wrong.)
B) For the same reasons as above, wouldn't E be 0?
C) really not sure where to go with this, guessing its an integral relying on the change in distance from each corner going from start position to infinity, and the the sum of those forces for each 8 corners.
Since it could move in a straight line through one of the faces, there would be 2 sets of 4 equal integrals, so I've gotten 4√(3)a/2Edr + 4-√(3)a/2Edr but even if this is right I have E = 0 so I can't do this.
F = kq1q2 / r2
E = kq / r
U
Hello,
Of course the net electric field at the center is zero.There are symmetrically opposing fields from all vertices.The charges are of the same nature and electric field is a vector.So I think your reasoning for questions a and b is correct. Potential however is a scalar so it has no direction.Just add the potentials due to individual charges ,or for the sake of symmetry seen here multiply potential due to one charge by 8.As far as your integral is concerned (which I will consider a difficult task to work with) see that E=0 only at the center of the cube.(or cuboid)It is not zero anywhere else inside the cube(or cuboid).
(Okay just a side question not related to the topic .Chemistry is not one of my strengths but I think the question should assign negative charges to chlorine ions,isnt it? :smile: )
regards
Yukoel
so inside the integral is Edr = kq1q2/ r2dr
which, when integrated, is -kq1q2/r
And since ΔV = - ∫Edr so the value i get turns positive, which seems like it would be correct. Then i would just plug in the numbers.
is this right?
is this right?
V is a function of the source charge only. What you are deriving is potential energy.Sign seems fine.
You can directly use the expression for potentials considering the point charges separately.Evaluating the integral is correct but unnecessary in your problem.
regards
Yukoel
  • · Replies 22 ·
  • · Replies 68 ·
9K
