Process of increasing solar cell efficiency- what's it like?
The discussion revolves around the process of increasing solar cell efficiency, exploring both analytical methods and experimental approaches in the field of solar energy technology. Participants share insights on current efficiency levels, research focuses, and the challenges faced in improving solar cell performance.
  • One participant expresses a general curiosity about the methods used to increase solar cell efficiency, questioning whether improvements come from analytical approaches or experimental trials with materials and designs.
  • Another participant notes that solar panels are already efficient enough that increasing their efficiency is not a significant barrier to their adoption.
  • A third participant provides links to resources that illustrate historical advancements in photovoltaic cell efficiency and outlines basic methods researchers employ to enhance it.
  • One participant highlights the limitations of solar energy availability at the Earth's surface, mentioning that only a fraction of solar energy can be converted into power, and suggests that research may be more focused on reducing costs and improving power storage rather than solely on efficiency improvements.
Participants do not reach a consensus on the primary focus of research in solar cell efficiency, with some emphasizing the importance of efficiency improvements and others suggesting that cost reduction and storage solutions may be more critical areas of investigation.
There are limitations in the discussion regarding the assumptions about solar energy availability and the specific methodologies used in research, which remain unresolved.
Fizicks1
I've recently gained an interest in solar cells and it's development. I know the basic working principle of solar cells, but other than that I'm quite clueless about the field.
I was wondering, what is the process of increasing solar cell efficiency like? Are there analytical ways of improving solar cell efficiencies? Or do researchers experiment with different material, structures, and designs through trial and error?
Any input is greatly appreciated!
Thanks.
I can't answer your exact question but it's worth noting that solar panels are already quite efficient and increasing their efficiency isn't a barrier to their adoption.
EDIT: link fixed
As you examine solar cell efficiency, do keep in mind that there is only about 1.4kw/m**2 of solar energy available at the Earth's surface at most.
The average amount is much less, because of the day/night cycle and clouds.
Only that residual, maybe 500w/m**2 on average, is available to generate power in solar cells.
Currently available solar cells are 10-20% efficient, so maybe a 100w/m**2 cell output on average if power storage is available.
Cutting cost of the cells or developing effective power storage are probably the areas of most intensive research currently, even more so than improving cell efficiency.
  • · Replies 16 ·
