Applied laws of gravity and fluid flow
The discussion centers on the behavior of fluid flow within a horizontally oriented cylinder, specifically a 25 ft long and 1 ft diameter cylinder filled with a hardening substance like cement. The presence of a 90-degree elbow at one end raises questions about whether gravity alone will enable the fluid to fill the cylinder completely before exiting. The consensus is that gravity will facilitate the flow, but the elbow's design may impact the flow rate and efficiency.
  • Understanding of fluid dynamics principles
  • Knowledge of gravity's effect on fluid flow
  • Familiarity with the properties of cement as a fluid
  • Basic concepts of pipe flow and fittings
  • Research fluid dynamics equations related to gravity flow
  • Explore the effects of pipe fittings on fluid flow rates
  • Study the viscosity and flow characteristics of cement mixtures
  • Learn about pressure loss in pipe systems due to bends and elbows
Engineers, fluid mechanics students, construction professionals, and anyone involved in material flow and application in cylindrical systems.
Rankty321
A cylinder, open at both ends, laying flat level is to be filled with a substance that will harden as cement.One end has a 90 elbow attached at one end in order to fill cylinder.The cylinder is 25 ft long and 1 ft in diameter.Will gravity alone take the fluid to the very end of the cylinder filling it completely before exiting at ends or not?
Is this homework? What have you done to try and solve the problem so far?
  • · Replies 24 ·
  • · Replies 45 ·
  • · Replies 31 ·
  • · Replies 48 ·
10K
