How Do You Calculate the Bounce Distance R(H, h) for a Marble?
The discussion focuses on calculating the bounce distance R(H, h) for a marble dropped from a height H + h onto a metal plate positioned at height h, angled at 45 degrees. The time to hit the bounce plate is determined to be sqrt(2H/g), leading to a velocity of g*sqrt(2H/g) at impact. The challenge lies in calculating the time of flight from the bounce plate to the ground and deriving the equation for R(H, h) using both vertical and horizontal components of velocity.
  • Understanding of kinematic equations in physics
  • Knowledge of projectile motion principles
  • Familiarity with the concept of gravitational acceleration (g)
  • Ability to analyze motion in two dimensions
  • Study the derivation of projectile motion equations
  • Learn about the effects of angle on projectile trajectories
  • Explore the concept of energy conservation in bouncing objects
  • Investigate the impact of different heights on bounce dynamics
Students in physics, educators teaching mechanics, and anyone interested in understanding the dynamics of bouncing objects and projectile motion calculations.
USAfightr
A marble has been dropped from a given height H + h. There is a metal plate directly below the marble at height h. The marble drops and hits the plate which is at 45 degrees and lands a distance away, R. Find an equation for R(H,h), that is finding the distance the marble bounces in terms of the two heights.
Position = Vx + volt - 1/2gt^2
I found that the time it takes to hit the bounce plate is sqrt(2H/g). Making the velocity at the bounce plate g*sqrt(2H/g).
I am having trouble finding the time of flight it takes from the bounce plate to the ground and then how to go about taking that and getting an equation for R(H,h).
The time of flight to the ground is determined by the vertical component of the velocity. The horizontal displacement will then be given by the horizontal component of the velocity and the time.
  • · Replies 28 ·
  • · Replies 25 ·
13K
