Difference between SAED pattern and XRD Pattern
  • Context: Graduate
  • Thread starter Thread starter yasir.ustb
    Difference Xrd
The discussion highlights the differences between Selected Area Electron Diffraction (SAED) patterns and powder X-ray Diffraction (XRD) patterns, specifically in the context of FeCo bcc alloy nanostructures. The XRD pattern shows only three reflections: (110), (200), and (211), while the SAED pattern reveals additional reflections such as (111), (100), and (122). This discrepancy is attributed to multiple scattering effects in electron diffraction, which are less prevalent in XRD. Additionally, the presence of weak reflections in SAED is enhanced due to the surface effects of nanoparticles.
  • Understanding of Selected Area Electron Diffraction (SAED)
  • Familiarity with powder X-ray Diffraction (XRD)
  • Knowledge of BCC (Body-Centered Cubic) crystal structures
  • Basic principles of multiple scattering in diffraction techniques
  • Research the principles of electron diffraction and its applications in materials science
  • Explore the effects of surface structure on diffraction patterns in nanoparticles
  • Investigate anomalous scattering techniques at synchrotron facilities
  • Study the B2 (CsCl-type) structure and its implications for alloy systems
Materials scientists, physicists, and researchers in nanotechnology who are analyzing diffraction patterns and studying the structural properties of alloy nanostructures.
yasir.ustb
Hello every one!
Why in SAED pattern some reflection are present but not in the powder XRD pattern? For example in my particular experiment FeCo bcc alloy nano structures, the XRD pattern contains only three reflection (110), (200) and (211). But in SAED pattern there are , reflection of (111), (100), (122), (211), (110) and (200).
Please explain why it is so?
Thanks a lot in advance
Multiple scattering is very very common in electron diffraction, but much less in x-ray diffraction (especially powder XRD).
(100), (111) and (221) are forbidden for BCC and therefore do not show up in normal x-ray diffraction.
FeCo can order in a B2 (CsCl-type) structure with Fe at the corner and Co in the center (or vice versa, same structure).
Then the structure is simple cubic and these reflections are allowed (but weak). Multiple scattering will amplify the intensity of these weak reflections, i.e. they would show more strongly in electron diffraction than x-rays.
This order is enhanced at surfaces (see article cited below). Nanoparticles being almost entirely surface, one would expect such order to be present. If you have access to a synchrotron, then trying an anomalous scattering experiment at the Fe or Co K-edge could be interesting.
http://prl.aps.org/abstract/PRL/v78/i20/p3880_1
Thank you very much Quak, I have understand it now clearly,
Also the article you suggested is very interesting, Once again thanks.
  • · Replies 21 ·
11K
