Instruments and Imaging: How to prevent condensation inside a closed system?
The discussion centers on methods to prevent condensation inside a closed optical system, specifically addressing issues related to dew accumulation on the inside of a corrector plate in an 8-inch Meade SCT telescope. Participants share various strategies and experiences related to this problem, which is particularly challenging in closed systems.
  • One participant mentions that condensation on the inside of the corrector plate can be problematic and seeks remedies from others.
  • Another participant suggests using dry nitrogen to flow over the affected area as a potential solution.
  • A different participant shares their experience using a handheld blow dryer to clear condensation, noting that it can be effective but may require frequent application depending on humidity levels.
  • One suggestion involves using a specific product designed to dry out the interior of the SCT, emphasizing the need to operate it in dry and warm conditions.
  • Another participant points out that dew shield and heater units are typically intended for external condensation and raises questions about how moisture entered the telescope in the first place, suggesting that prior maintenance may have contributed to the issue.
Participants express various methods to address the condensation issue, but there is no consensus on a single effective solution. Multiple competing views and strategies remain, reflecting differing experiences and approaches to the problem.
Some limitations are noted, such as the dependence on environmental conditions (humidity levels) and the potential for moisture ingress during maintenance activities. The discussion does not resolve how moisture initially entered the telescope.
Astrid
Dewing of a mirror or object glass can be countered with various devices
and methods, but its occurrence inside a closed system is particularly
problematic. I have received the following enquiry (from an experienced
observer who has used several instruments over many years) concerning
dew on a corrector plate, and would be pleased to hear from anyone who
who has a remedy:
'Having recently obtained an 8-inch Meade SCT I have been having serious
problems with condensation, which persistently accumulates on the inside
of the corrector plate. I have fitted a dew shield and tried a heater,
but these have been only partially successful in limiting and/or
delaying the inevitable.'
Astronomy news on Phys.org
Have you tried flowing dry nitrogen over the affected area?
The INSIDE of the corrector plate? Wow. I have a Schmidt-Newtonian and I use a hand held blow dryer, like the ones women dry their hair with, as a final resort if things get bad. It works pretty well and can even clear the inside of the corrector plate in a minute or two. It just sucks because sometimes you have to apply it every 15 minutes or so depending on how humid it is.
Your friend needs a http://www.lymax.com/sct/. Run it inside the house where it is dry and warm to dry out the interior of the SCT.
Dew shield/heater units are for condensation on the outside of the corrector plate...
something all us SCT owners suffer from, unless you live at really high altitude ;)
As hinted at by others... you really need to purge the inside of the scope OTA under the driest (read lowest humidity) conditions possible and consider filling the OTA with nitrogen to purge the damp air
this leads to the question tho ... how did moisture get in there in the first place ?
Have you had the OTA apart for main mirror cleaning etc ?
Dave
