Higher order DE to State space
The discussion focuses on converting higher-order differential equations (DE) into state space format for use with the ODE45 solver in Matlab. The user initially describes the conversion of a second-order differential equation into a first-order state space format, exemplified by the equation d2x/dt2 + dx/dt - 1 = 0. The user seeks guidance on handling more complex equations, specifically d2z/dt2 + d2x/dt2 + dx/dt - 1 = 0, and how to implement this conversion in Matlab. The recommended methods for achieving this include Phase Canonical Forms of State Space Equation and State Space Equation Generation via Nested Integrals.
  • Understanding of second-order differential equations
  • Familiarity with state space representation
  • Proficiency in Matlab programming
  • Knowledge of ODE45 solver functionality
  • Learn how to implement Phase Canonical Forms of State Space Equation in Matlab
  • Explore State Space Equation Generation via Nested Integrals
  • Study the use of ODE45 for solving state space equations
  • Investigate additional methods for converting higher-order DEs to state space format
Matlab users, engineers, and researchers working with dynamic systems who need to convert higher-order differential equations into state space format for simulation and analysis.
anirudh_s
Hey,
I've been trying to run a few simulations in Matlab using ODE45. This algorithm requires a function which gives the first order differential as an output i.e a state space format (Correct me if I'm wrong here).
If its a normal N order differential such as d2x/dt2 + dx/dt -1 =0 . dx/dt can be substituted as y and hence the differential equation becomes:
y(dot) = 1-y i.e. the required state space format.
Now comes the question , what do I do if the DE is something like
d2z/dt2 + d2x/dt2 +dx/dt -1=0 ? How Do I convert this to state space format ?
And more specifically , how do I code this as a function to use in ODE45 in Matlab ?
Thanks in advance!
There are second order derivatives so you you will have two state variables. You then use one of following methods:
- Phase Canonical Forms of State Space Equation
- State Space Equation Generation via 'Nested Integrals'
There are other methods as well.
  • · Replies 65 ·
10K
