Dielectric and Parallel Plate Capacitor, the point?
The discussion centers around the role and implications of using a dielectric material in a parallel plate capacitor. Participants explore the effects on capacitance, potential difference, charge, and potential energy, as well as practical considerations in capacitor design.
  • One participant questions the purpose of a dielectric, noting that while it increases capacitance, it also lowers the potential difference, leading to confusion about its benefits.
  • Another participant explains that a solid dielectric allows for smaller capacitor sizes for a given capacitance and facilitates construction by maintaining plate separation.
  • A third participant clarifies that the capacitance formula does not include potential difference, suggesting that capacitance is independent of it, and discusses the relationships between charge, capacitance, and potential energy.
  • One participant provides a link to external resources, suggesting they may help clarify the topic further.
Participants express varying levels of understanding and confusion regarding the implications of using a dielectric. There is no consensus on the overall benefits or drawbacks of dielectrics in capacitors, and multiple viewpoints remain present.
Some assumptions about the relationships between capacitance, charge, and potential energy are discussed, but not all participants agree on these interpretations. The discussion reflects a range of understandings and uncertainties regarding the topic.
RadiantL
Hi, so I'm having a little trouble understanding why... you would put a dielectric in between a parallel plate capacitor? I know it increases the capacitance but it does so by lowering the potential difference sooo... The charge is still the same, I believe the potential energy also decreases as well. (correct me if any of what I said was wrong, sorry)
So yeah, if I got my thinking straight, what's the point of putting a dielectric in there? Also am I wrong to say increasing the capacitance, here would do nothing... well great?
Thanks
Putting a solid dielectric in a capacitor increases the capacitance and so reduces the size of a capacitor for a given capacitance.
It also makes construction of the capacitor easier. Somehow, you need to hold the plates of the capacitor apart and this is not easy with an air dielectric.
Air dielectric capacitors are still used for very small capacitors, especially if they are variable capacitance ones for tuning of resonant circuits.
They are not normally made larger than 1000 pF, though. This is 1 nano Farad or 0.000 000 001 Farads. Such a capacitor would be several cubic inches in volume while a capacitor of 1 Farad can be made in about a cubic inch, because it has a solid dielectric. (Well, the dielectric is an oxide coating on the metal electrodes although the capacitor contains a jelly-like substance.)
RadiantL,
The capacitance of a parallel plate capacitor is k*ε*A/d, where k is the dielectric constant, ε is the permittivity of free space, A is the plate area, and d is the plate separation. Do you see potential difference in that formula? No? Then the capacitance is invariant with respect to potential difference.
The charge imbalance? That depends on the capacitance and voltage, doesn't it? Q=C*E . The potential energy? That depends on (1/2)*C*E^2 or (1/2)*(Q^2)/C, doesn't it?
Ratch
Thanks for the replies! That, and a little bit of careful reading helped, clear up my mind a little :P
  • · Replies 30 ·
