Double Intergral with Substitution
  • Context: Undergrad
  • Thread starter Thread starter BenMcC
    Substitution
The discussion revolves around a double integral problem involving the function e^(y^2) and the challenge of evaluating it correctly using substitution and changing the order of integration. The scope includes mathematical reasoning and problem-solving techniques related to calculus.
  • Homework-related
  • One participant expresses difficulty in solving the double integral and seeks help, stating that the expected answer is (e^4)-1.
  • Another participant suggests converting the integral into a more readable format and proposes sketching the integration area in the x,y-plane.
  • A participant mentions confusion regarding the initial integral and attempts to use u-substitution but finds it unhelpful.
  • One participant points out that an antiderivative of e^(y^2) cannot be found and emphasizes the importance of changing the order of integration to simplify the problem.
  • Another participant acknowledges the need to change the order of integration but expresses uncertainty about how to set it up correctly.
  • A later reply suggests that evaluating the integral with respect to x first may simplify the process, highlighting the need to determine new bounds for the integrals.
Participants generally agree that changing the order of integration is a key step, but there is no consensus on how to set it up or the best approach to evaluate the integral. Multiple competing views and methods are presented without resolution.
Some participants mention limitations in finding an antiderivative for e^(y^2) and the complexity of determining new bounds when changing the order of integration. These aspects remain unresolved within the discussion.
BenMcC
I have a problem with Double Integral that I can not seem to get correct.
4 2
∫ ∫ e^(y^2)dydx
0 (x/2)
The answer is (e^4)-1, but I can't seem to get the Substitution at all right. I have literally spent hours on this problem. Any help would be greatly appreciated, its also due by 3:30, so I am kind of limited by time. Thanks
3:30 in which time zone? ;)
Here at me, you asked your question at 5:09 PM.
Converted in a format that is easier to read:
$$\int_0^4 \left(\int_{x/2}^2 e^{y^2} dy\right)dx$$
Did you draw a sketch of the integration area (in the x,y-plane)? The integral is equivalent to
$$\int_0^2 \left(\int_{0}^{2y} e^{y^2} dx\right)dy$$
There, both integrals are easy to evaluate in that order.
I have 4 hours, so I have time. I'm just really confused how to do the initial integral. I tried u substitution of u*dv=uv-∫v*du, and I can't get it to come out quite right
You cannot find an antiderivative of ##e^{y^2}##. It is nice to try, but you won't get a result unless you just define it (but that does not help here).
The change of the integration order (or something equivalent) is the key point here. It allows to evaluate one integral and simplifies the other one.
It's possible. It says to change the order of integration, and I have no idea how to set that up
As you may or may not see, evaluating it with regards to x first will let you solve the whole thing. The trick is just the figure out the new bounds on the integrals - it's not as simple as just switching the order.
What I would do is the draw a graph and draw the lines x=4, x=0, y=2 and y=x/2.
Then think about what the bounds would be if you were looking at it 'sideways'.
EDIT: Just realized mfb gave you the integral already, so you don't need what I said.
