If light appears frozen due to time dilation, how do its fields fluctuate?
The discussion revolves around the implications of time dilation and Lorentz contraction for particles traveling at the speed of light, particularly photons. Participants explore the conceptual challenges of understanding how light behaves under these relativistic effects, questioning the nature of existence and perception of time and distance for massless particles.
  • Some participants express confusion about the transition from subluminal to luminal speeds, particularly regarding the implications of Lorentz contraction and time dilation for photons.
  • One participant questions whether a photon, traveling at the speed of light, experiences a path length of zero and does not age, leading to existential inquiries about its existence.
  • A later reply clarifies that while the proper time along a light ray is zero, the elapsed coordinate time and distance in any observer's frame are not zero, suggesting that the statement about light not moving or aging is misleading.
  • Another participant reflects on their intuitive understanding of time, suggesting that it may be unrealistic when considering relativistic effects and acknowledges the limitations of human perception in grasping these concepts.
  • One participant asserts that there is no time or distance relative to a photon, indicating that these concepts are undefined or meaningless in that context.
Participants do not reach a consensus on the implications of time and distance for photons. There are competing views regarding the interpretation of Lorentz contraction and time dilation, and the discussion remains unresolved.
The discussion highlights limitations in understanding relativistic effects, particularly the challenges in reconciling intuitive notions of time and distance with the behavior of massless particles. The philosophical implications of defining frames of reference at the speed of light are also noted.
d3mm
I guess I have no problem with time dilation for stuff moving at less than c, but the step from less than to to c, is confusing me.
Then don't take the step. It's impossible.
Is it true that for a particle (like a photon) traveling at c, that Lorentz contraction makes its path length =Zero (i.e. it doesn't move)
And also that time dilation means that it does not age.
Therefore we end up with something that doesn't move and doesn't age??
Does it even exist?
?! Help! Brain melting
FAQ: What does the world look like in a frame of reference moving at the speed of light?
This question has a long and honorable history. As a young student, Einstein tried to imagine what an electromagnetic wave would look like from the point of view of a motorcyclist riding alongside it. But we now know, thanks to Einstein himself, that it really doesn't make sense to talk about such observers.
The most straightforward argument is based on the positivist idea that concepts only mean something if you can define how to measure them operationally. If we accept this philosophical stance (which is by no means compatible with every concept we ever discuss in physics), then we need to be able to physically realize this frame in terms of an observer and measuring devices. But we can't. It would take an infinite amount of energy to accelerate Einstein and his motorcycle to the speed of light.
Since arguments from positivism can often kill off perfectly interesting and reasonable concepts, we might ask whether there are other reasons not to allow such frames. There are. One of the most basic geometrical ideas is intersection. In relativity, we expect that even if different observers disagree about many things, they agree about intersections of world-lines. Either the particles collided or they didn't. The arrow either hit the bull's-eye or it didn't. So although general relativity is far more permissive than Newtonian mechanics about changes of coordinates, there is a restriction that they should be smooth, one-to-one functions. If there was something like a Lorentz transformation for v=c, it wouldn't be one-to-one, so it wouldn't be mathematically compatible with the structure of relativity. (An easy way to see that it can't be one-to-one is that the length contraction would reduce a finite distance to a point.)
What if a system of interacting, massless particles was conscious, and could make observations? The argument given in the preceding paragraph proves that this isn't possible, but let's be more explicit. There are two possibilities. The velocity V of the system's center of mass either moves at c, or it doesn't. If V=c, then all the particles are moving along parallel lines, and therefore they aren't interacting, can't perform computations, and can't be conscious. (This is also consistent with the fact that the proper time s of a particle moving at c is constant, ds=0.) If V is less than c, then the observer's frame of reference isn't moving at c. Either way, we don't get an observer moving at c.
Is it true that for a particle (like a photon) traveling at c, that Lorentz contraction makes its path length =Zero (i.e. it doesn't move) And also that time dilation means that it does not age.
Along the path of a light ray, the path length (proper time) is zero. But the elapsed coordinate time and distance in the reference frame of any observer is not zero. So to say the light ray doesn't move and doesn't age is not the case.
Thinking about this and the replies, especially the excellent one from bcrowell, leads me to the conclusion that I am thinking of time in intuitive but unrealistic way, hence am suffering from an apparent paradox. Or in other words, I should just accept that I don't have the sensory equipment to perceive the result properly.
Would that agree with the consensus?
Yes. You will find that in cosmology, and even more so in quantum mechanics, the things being studied are simply not ones that are part of our everyday lives and thus our built up "intuition" just isn't useful. It would SEEM that time IS in our everyday experience, but when relativistic speeds come in, it is not.
There is no time or distance relative to a photon. That doesn't mean time and distance are zero, it means they are undefined or meaningless. We have a related FAQ: Rest frame of a photon
  • · Replies 46 ·
  • · Replies 16 ·
  • · Replies 47 ·
  • · Replies 18 ·
  • · Replies 25 ·
  • · Replies 58 ·
