Newton Raphson Method on Fortran90
The discussion revolves around implementing the Newton-Raphson method in Fortran90 to compare its effectiveness with the bisection method for solving the equation x3−2x−2 = 0, which has a single root between x=−4 and x=2. Participants are seeking guidance on iteration processes within the method.
  • Technical explanation, Homework-related
  • One participant outlines the task of comparing the bisection method and Newton's method for a specific equation and expresses uncertainty about how to perform iterations.
  • A code snippet for the Newton-Raphson method is provided, demonstrating the iteration process and error calculation.
  • Another participant confirms that the provided code represents the iteration process and encourages running it to verify the solution.
Participants appear to agree that the provided code implements the iteration process, but there is no explicit consensus on the overall effectiveness of the methods being compared.
The discussion does not address potential limitations or assumptions related to the convergence of the Newton-Raphson method or the specific characteristics of the equation being solved.
Individuals interested in numerical methods, particularly those learning about root-finding algorithms and their implementation in programming languages like Fortran90.
jhosamelly
Here's what I need to do:
"Compare the effectiveness of the bisection method and Newton’s method for the
equation x^3−2x−2 = 0 which has a single root between x=−4 and x = 2."So far I've done
ok. this is working but of course I need to do iteration which I don't know how. Can someone teach me please? I'm trying the Newton-Raphson Method first.
Thanks for the help in advance.EDITED: Sorry, I posted the wrong pic earlier. Here's the correct one.
Technology news on Phys.org
Code:
program nr
real:: x, xnew, err
write(*,*) "starting x?:"
read(*,*) x
do
    xnew = x - ( (x**3 - (2*x) - 2) / ( ( 3*(x**2) )-2) )
    err = 100*abs( (xnew-x)/x )
    x = xnew
    write(*,*) "x = ", xnew, "  error = ", err
    if (err < 0.000001) exit
end do
end program nr
thanks :))) Is that the iteration already?
Yes.
Isn't it? Run it and verify the solution
  • · Replies 16 ·
  • · Replies 16 ·
