Gaussian Radius of curvature in an argon ion laser
The discussion focuses on calculating the radius of curvature of the beam in an argon ion laser with a wavelength of 514nm and a minimum beam waist of 1.0mm, positioned 1.15m from the output mirror. The user initially applied the formulas θ = 2λ/πW0 and R = Z + ZR2/Z, but miscalculated the radius of curvature, arriving at R = 33.5m instead of the correct value of R = 3.08m. The error stemmed from a misunderstanding of beam width versus beam radius.
  • Understanding of Gaussian beam optics
  • Familiarity with argon ion laser specifications
  • Knowledge of beam waist and radius of curvature calculations
  • Proficiency in using formulas related to laser beam propagation
  • Study Gaussian beam propagation principles
  • Learn about the characteristics of argon ion lasers
  • Review calculations for beam waist and radius of curvature
  • Explore advanced laser optics and their applications
Laser physicists, optical engineers, and students studying laser technology will benefit from this discussion, particularly those focused on Gaussian beam behavior and laser design principles.
lauraboyleify
Hi, having a bit of trouble with this question
"In an argon ion laser ( λ = 514nm) the minimum beam waist is 1.0mm and is close to the plane mirror. Calculate the radius of curvature of the beam at the output mirror. 1.15m away"
Attempt at a solution:
θ = 2λ/pi W02
R = Z + ZR2/Z
ZR = piW02 / λ
I used
W0 = min beam waist = 1.00 mm
Z= distance from beam waist to mirror = 1.15m
And found Zr with the formula and used it in the Radius of curvature, R formula but got the worng answer. I got R = 33.5m
The answer given is R = 3.08m
Beam width isn't beam radius!
  • · Replies 0 ·
  • · Replies 0 ·
