Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Classical Physics (http://www.physicsforums.com/forumdisplay.php?f=61)
-   -   Why does valence electrons not produce electric field in the space? (http://www.physicsforums.com/showthread.php?t=659187)
ankities Dec16-12 03:52 AM
why does valence electrons not produce electric field in the space?
let X be any hypothetical isolated neutral atom and X- be the anion formed when X gain 1 electron
this extra electron is in the valence energy orbit(band) and X- being charged produces electric field
check me if i m wrng above
now X(neutral) also consists of electrons in the valence band but it does not produce electric field in the space ?
can u pl explain the mechanisms involved .....
K^2 Dec16-12 05:04 AM
Re: why does valence electrons not produce electric field in the space?
They do. That electric field cancels out the electric field created by positively charged nucleus. If you remove an electron instead, creating a cation, the cancellation is incomplete, and the overall charge is positive.
HomogenousCow Dec16-12 09:05 AM
Do note that chemists use really wonky electrodynamics, we can't really define an electric field for a quantum object because it's motion is uncertain
K^2 Dec16-12 10:13 AM
Quote:
Quote by HomogenousCow (Post 4198783)
That is entirely false.
HomogenousCow Dec16-12 10:35 AM
Well can you calculate the electric field of an electron in a hydrogen atom, or at least write a differential equation for it?
Nugatory Dec16-12 11:04 AM
Quote:
Quote by ankities (Post 4198547)
The classical answer (the QM answer would be a lot more work but doesn't change anything qualitatively) is that there is an electromagnetic field if you get close enough to even a neutral atom, and indeed that's why some forms of atomic bonding happen.
However, for a neutral atom this field disappears if you move even a few tens of atomic radii away from the atom. Take the simplest case, hydrogen, with one proton and one neutron. At a point far away from the atom, the electrical fields of the proton are near as no never mind equal in strength (because the distance to the proton is near as no never mind equal to the distance to the electron) and pointing in near as no never mind in opposite directions (opposite charges, but very close to each other) so they pretty much cancel.
But if the atom has gained or lost an electron so that's it ionized, then the magnitudes of the two contributions no longer cancel - there's a net positive or negative charge. An ion with N protons in the nucleus and N-1 electrons around it looks more and more like a point charge of +1 the farther away from it you get.
K^2 Dec16-12 09:55 PM
Quote:
Quote by HomogenousCow (Post 4198885)
Maxwell's Equations with ##\small \rho = q_e\psi^{*}\psi##. Here, ##\small q_e## is the electron charge. So long as there is no transition, magnetic field remains constant and we have ##\small \nabla\cdot E=\rho/\epsilon_0## and ##\small \nabla\times E=0##. The reason all of this works is that E is a linear field, so an electric field from superposition of sources is a superposition of fields from these sources, and that's just a sum of these fields. So probability density of electron is the charge density of electron. If you have entanglement, things can get interesting, but otherwise, it's extremely straight forward. So lets look at the hydrogen atom in ground state.
[tex]\psi_{100}(r) = \frac{1}{\sqrt{\pi a_0^3}}e^{-r/a_0}[/tex]
Here, ##\small a_0## is the Bohr Radius, of course. This gives us a perfectly spherically symmetric distribution, so applying Gauss law, the equation for electric field follows.
[tex]E(r) = \frac{1}{4\pi \epsilon_0}\frac{q_e\hat{r}}{r^2}\int_0^r \psi_{100}^{*}(r)\psi_{100}(r) dr = \frac{1}{4\pi \epsilon_0}\frac{e\hat{r}}{r^2}\left( 1-\frac{e^{-2r/a_0}(a_0^2+2ra_0+2r^2)}{a^2} \right)[/tex]
Of course, that's just the electron charge. If we say that nucleus has charge ##\small q_p = -q_e##, and we assume it to be a point source, which it really close to being, then we have the net electric field in the neighborhood of a hydrogen atom.
[tex]E(r) = \frac{q_p\hat{r}}{4\pi \epsilon_0}\frac{a_0^2+2ra_0+2r^2}{a_0^2r^2}e^{-2r/a_0}[/tex]
Note that because of the exponent, this is basically zero for ##\small r>>a_0##.
GarageDweller Dec16-12 10:00 PM
But then what happens when I go and perform a position measurment on the electron?
HomogenousCow Dec16-12 10:11 PM
Quote:
Quote by K^2 (Post 4199633)
I'm skeptical about the charge density simply being the probability density times the electron charge, that would imply that the electron be spread out throughout space. The electron does have a position upon measurment and we should get the usual 1/r^2 field if we measure the electric field right after.
Besides I really doubt we can apply classical EM to the electron, for example if one makes a position measurment that still leaves the momentum uncertain, hence we cannot know if there is a magnetic field.
K^2 Dec17-12 12:16 AM
What happens in a measurement is a separate question. It will depend on exactly what it is that you are measuring and how. Once you have the interaction associated with the measurement you can find its eigen functions and figure out what will happen to electron's wave function after the measurement.
That, up there, is how you compute an electric field due to an electron with a given wave function.
HomogenousCow Dec17-12 12:28 AM
Could you elaborate on why ρ=qeψ∗ψ, I am aware that EM is linear and hence you can superposition sources, but I cannot see why the electron's charge is spread out throughout space. As I understand it, the electron is still a point particle in QM, just that it's position does not exist prior to observation, the state vector projected in the position basis only gives the probability density for finding it in some given volume, and does not represent some kind of "spread".
K^2 Dec17-12 01:04 AM
Quote:
Quote by HomogenousCow (Post 4199752)
It's simply a mis-understanding of significance of wave function on your part, then. Electron is a point particle, and as any point particle, it has a specific location. Of course, the total state is a superposition of such locations. ψ(x) is the coefficient of the state located precisely at x. That component of the state produces electric field as if electron was precisely at x. Then you need to sum over components to get the total state. In the process, you accumulate an electric field equivalent to that produced by charge distribution ψ*ψ. Until you get entanglement into the picture or start looking at interactions, it really doesn't matter if you have a point particle with given probability distribution, or an actual distributed object. Charge density is still proportional to probability density.
HomogenousCow Dec17-12 06:14 AM
could you link to some website that agrees with you, because this is all news to me
mfb Dec17-12 09:35 AM
Most books for an introduction to QM should have this in some way.
<- not a website, but agrees with K^2, too.
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
