Solve Universal Gravitation Homework: Find Distance between Moon & Satellite
  • Thread starter Thread starter mtayab1994
    Universal
The problem involves determining the distance from a satellite (S) to the moon (dm) when the forces acting on the satellite are balanced. The context is universal gravitation, with the distance between the Earth and the moon given as 38*10^4 km and the mass of the Earth being 81 times that of the moon.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss starting points based on Newton's law of universal gravitation and the relationship between distances from the satellite to the Earth and the moon. There are attempts to set the gravitational forces exerted by both the Earth and the moon equal to each other to find the distance dm.
The discussion includes various approaches to the problem, with some participants providing calculations and others seeking clarification on the steps taken. There is acknowledgment of correct results, but also requests for more detailed explanations of the reasoning and calculations involved.
Some participants express difficulty in following the calculations due to the presentation of information, indicating a need for clearer communication of steps and reasoning.
mtayab1994
Let (S) be a satellite between the Earth and the moon such that (S) is at a distance dm from the moon. All forces on the the satellite are null (equal zero). Find the distance dm .
Given: Distance between moon and Earth is 38*10^4km and the mass of Earth is 81 times the mass of the moon.
Well it's been a long time since I've done any universal gravitation. It would be nice if someone can just give me an idea on how to start and I'll go from there.
Start with Newton's law of universal gravitation. Link
If the distance between the moon & the satellite is dm , then what is the distance between the satellite & the Earth ?
The distance between the Earth and the satellite is d=D-dm and Newton's law of gravitation says that F=(G*m1*m2)/(r^2)
Let's name the distance from Earth to the satellite by D. So D=d-dm.
And by using g=(GM)/D^2 we get that the distance from the Earth is 6.36*10^3 km.
So that means the distance from the satellite to the moon is
d-D=3.8*10^5-6.36*10^3=3.74*10^5 km. Is that correct??
It's not clear what all you put together to get that result.
Please fill in and explain some steps.
My approach would be set the magnitudes of the following two forces equal to each other.
The force exerted on the satellite by the moon.
The force exerted on the satellite by the earth.​
By setting the forces equal to one another i got in the end:
Me/Mm=dm^2/de^2 and we know that the mass of the Earth is 81 times the mass of the moon so we get 81Mm/Mm=(dm^2)/(de^2) and then we cancel with the mass of the moon and square root both sides and we are left with. √81=dm/de and we know that the distance from the satellite and the Earth is d-dm. and by doing some simple algebra we find that the distance to the moon is d/10 the total distance between the moon and Earth so that gives us
3.8*10^4 km.
Me/Mm=dm^2/de^2 and we know that the mass of the Earth is 81 times the mass of the moon so we get 81Mm/Mm=(dm^2)/(de^2) and then we cancel with the mass of the moon and square root both sides and we are left with. √81=dm/de and we know that the distance from the satellite and the Earth is d-dm. and by doing some simple algebra we find that the distance to the moon is 9/10 times the total distance between the moon and Earth so that gives us
3.42*10^5 km. Is that correct now??
It's quite difficult to try to figure out what all you have done to get your answer. Having youe text all packed together so tightly doesn't help either.
[itex]\displaystyle G \frac{M_m\, m}{{d_m}^2}=G \frac{M_e\, m}{(d-d_m)^2}\,,\[/itex]
where Mm is the moon's mass, Me is the Earth's mass, m is the satellite's mass, dm is the satellite's distance from the moon, and d is the monn's distance from earth.
Me = 81 Mm. Plugging this in & doing some manipulation gives:
[itex]\displaystyle \frac{M_m}{{d_m}^2}=\frac{81M_m}{(d-d_m)^2}\[/itex] [itex]\displaystyle\quad\to\quad d-d_m=d_m\sqrt{81}=9d_m\[/itex] [itex]\displaystyle\quad\to\quad d_m=\frac{d}{10}\[/itex]
Well, yes, your answer is correct.
  • · Replies 18 ·
