Is Feynman's interpretation of the double slit experiment universally accepted?
  • Context: Graduate
  • Thread starter Thread starter I2004
    Double slit Slit
The discussion centers around the interpretation of the double slit experiment, specifically regarding whether particles such as electrons or photons can be said to "split" and go through both slits simultaneously, as suggested by Feynman's interpretation. Participants explore the implications of this interpretation and its acceptance within the physics community.
  • Some participants question whether the idea that particles go through both slits is a proven fact or merely an interpretation of the results.
  • One participant emphasizes that the experiment shows an interference pattern, which suggests a wave-like behavior rather than particles going through one slit or the other.
  • Another participant describes Feynman's approach as combining all possible timelines rather than having the electron split and interfere with itself, proposing a model where the electron can traverse back and forth in time.
  • A participant argues that the wavefunction provides statistical predictions based on the experiment's geometry, and that the concept of particles interfering is an interpretation rather than a definitive description of reality.
  • Some participants express confusion about the acceptance of the idea that particles can be in two places at once, with one explicitly stating that this is not universally accepted.
  • There is a reiteration that interpretations of quantum mechanics, including Feynman's, allow for multiple perspectives without a definitive consensus on the nature of particles in the double slit experiment.
Participants generally do not agree on whether the interpretation that particles split and go through both slits is universally accepted. Multiple competing views remain, with some supporting the idea and others rejecting it.
Participants note that interpretations of quantum mechanics can lead to confusion and that the language used to describe phenomena may imply incorrect or magical concepts. The discussion highlights the complexity and nuance of interpreting experimental results in quantum mechanics.
I2004
in the experiement does the electron/photon always split and physically go through both slits or is this just an interpretation of the results?
I believe this is Feynmans interpretation. is it universally accepted?
I just don't understand if its actually a proven fact that it goes through both(or indeed all possible infinite paths) or is just an interpretation.
Please help
The proven fact is:
If both slits are open and you make no attempt to interfere with the electrons (for example, by trying to detect their position) while they are in flight, and send the electrons one at a time, then
- Each individual electron will make a single discrete dot on the screen.
- Run the experiment long enough, and the dots will build up to form a pattern on the screen.
- The pattern is not two blotches, one behind each slit, as you would expect if each individual electron went through one slit or the other. Instead it is the interference pattern that would be produced by waves going through both slits at once, and that you can calculate using the sum-of-all-paths method.
Just about anything beyond "the math works and predicts this result" is an interpretation.
You mention Feynman, and I think he may be the only person who does not characterize this as having the electron split and interfere with itself.
Instead, he prefers the approach where you combine all possible timelines and let them interact. So it is more like the electron is free to go back and forth freely in time before deciding on its ultimate destination, but all of the forward paths interfere with all of the 'previous' forward paths in this very long 'lifetime' of time-reversals. So when it comes forward again, it needs to avoid the other paths that it 'tried out' and chose not to take, as if there were another electron that *did* choose to take them.
To make the point in an extreme way, he once proposed that there is only one electron in all the universe, but it has gone back in time often enough to be all of the existing electrons we see now. It captures a way of looking at quantum mechanics that is less bizarre than the possibility function with a collapsing wavefront.
I think it is the view that Hawking proposed we should take for why black holes last as long as they do before they evaporate into virtual particles. (I gather that it did not go over well, and was seen as cheating, but it is among the historically proper approaches to the problem.)
A photon interferes with itself.If you measure from which hole photon gets through interference disappears.
The wavefunction that describes the electron is calculated based on the geometry of the experiment and provides a statistical prediction of which screen locations are more probable than others. The wavefunction is a vector field, and so when two of them are superimposed, the vectors at each point are summed. Vector addition is what makes interference patterns emerge when you would expect to see two blobs in the double slit experiment.
"Particles" interact via forces. They do not interfere with each other or themselves. The vector field which predicts probable outcomes of an experiment does interfere, which is simply stating that sometimes the sum of two vectors has a smaller absolute value than the absolute value of either of the vectors.
This doesn't answer your question, its just me being fussy because I'm annoyed that certain popular statements about QM imply incorrect, magical things because of their inaccurate wording.
The wavefunction is formulated with no assumptions about the number of "particles" that are present, on the contrary, it would be much more difficult if particle-particle interactions were considered. It can be normalized to any number you want so it shouldn't be surprising when it works as well for low intensities as for high...
The one assumption that all paradoxical and unintuitive scenarios share is the assertion that there is any such thing as "particles" in the first place. So I would say that the "particle" splitting and taking both paths is an interpretation of the results, as well as the existence of the particle. I know this is not what you wanted to hear. Sorry.
I love this idea, since the arrow of time is something that arises from the tendency of thermal systems to maximize disorder purely because all states are equally likely and the number of states of maximum disorder is astronomically large compared to all others, there is no reason for it to apply to a single electron.
But since the wavefunction does not consider particle-particle interactions, and would be different if it did so, how can a model in which the particle reverses direction in time and affects itself, through the electromagnetic force I assume, produce the same predictions?
my original question is, is it accepted that the particle splits and goes through both slits at once so the particle is in 2 places at one?
anyone have an answer please?
No, that is not universally accepted. As with any interpretation, nothing awful will happen if you think about it that way, but you could reasonably choose to think about it some other way if you would rather.
(I feel like repeating #3 in this thread. I thought it answered your question).
No.
https://www.youtube.com/watch?v=FCoiyhC30bc
  • · Replies 26 ·
  • · Replies 20 ·
  • · Replies 24 ·
  • · Replies 36 ·
10K
  • · Replies 24 ·
  • · Replies 32 ·
