How does fixed line level attenuation work?
  • Context: Undergrad
  • Thread starter Thread starter ohms
    Attenuation Line
The discussion clarifies that fixed line level outputs in audio systems maintain a constant signal level, independent of volume control settings. This is due to their connection in the signal path, typically situated after the preamplifier but before the tone and volume control blocks. The line output is designed to interface with various devices, such as speakers and headphones, without being influenced by the volume adjustments intended for speaker outputs. Understanding this configuration is essential for grasping how different outputs function in a hi-fi system.
  • Understanding of audio signal flow in hi-fi systems
  • Familiarity with preamplifiers and their role in audio processing
  • Knowledge of different audio output types (line, speaker, headphone)
  • Basic comprehension of block diagrams in audio engineering
  • Research the role of preamplifiers in audio signal processing
  • Learn about the differences between line outputs and speaker outputs
  • Explore audio signal flow diagrams for better visualization
  • Investigate the impact of volume controls on various output types
Audio engineers, hi-fi enthusiasts, and anyone involved in designing or understanding audio systems will benefit from this discussion.
ohms
hello all
first post here and I'm interested in some info you people may hold :smile:
in layman's terms I'm trying to understand how a fixed line level can attenuate.
according to wikis line level page the 'the signal out or line out remains at a constant level, regardless of the current setting of the volume control', i understand the statement but not the engineering behind it i.e how you attenuate a signal that is fixed
hope you can shed some light here
regards
You don't, they aren't talking about the same signals.
Typically a hifi system will have several outputs. For example there might be speaker outputs, line outputs, headphone outputs etc Each output is intended to be connected to a different type of device. Some systems will even have digital outputs, perhaps capable of streaming the signal to a network.
Normally if the system has a volume control it only affects the speaker outputs but sometimes they are designed to affect other outputs as well. Normally the line output is not affected by the volume controls.
Here is a block diagram..
http://www.kpsec.freeuk.com/images/audio.gif
Although not shown on the diagram the line output would be connected after the preamp but before the tone and volume control block. A Line Input might also be provided and this would also be connected at this point.
PS. I've looked for a better block diagram online but to my surprise I've not been able to find one showing a traditional hifi amplifier.
15K
12K
  • · Replies 22 ·
