Ruben's Tube - Is a one inch OD pipe okay?
  • Context: High School
  • Thread starter Thread starter 012anonymousx
    Pipe Tube
The discussion revolves around the feasibility of using a one-inch outer diameter (OD) pipe for constructing a Ruben's tube, a device that visualizes sound waves through flames. Participants explore theoretical implications, practical experiences, and potential challenges related to the smaller diameter compared to the more commonly used larger sizes.
  • Experimental/applied
  • One participant questions whether a one-inch diameter pipe can work, noting that most tutorials recommend at least a two-inch diameter.
  • Another participant suggests that while the wave effect might be diminished and some distortion could occur, it should not prevent the final waveform from being visible.
  • Concerns are raised about gas flow velocity being higher in a smaller diameter tube, which may distort standing waves.
  • It is mentioned that resonance peaks may not be as sharp in a narrower tube due to energy loss being more significant in the boundary layer around the tube's surface.
  • A participant shares their experience with a one-inch black pipe, reporting limited success in achieving desired sound wave patterns and seeking troubleshooting advice.
  • Another participant notes their ongoing construction of a larger Ruben's tube with specific hole dimensions and spacing, expressing uncertainty about the effectiveness of their design.
  • Some participants discuss the spacing of holes and the impact on flame behavior and sound propagation, with suggestions for adjustments based on personal experiences.
Participants express a mix of opinions regarding the use of a one-inch diameter pipe, with some suggesting it may work but acknowledging potential limitations. The discussion remains unresolved, with no consensus on the effectiveness of the smaller diameter.
Participants highlight various assumptions about gas flow dynamics, resonance, and the practical challenges of construction, but these factors remain unresolved and contingent on specific setups.
012anonymousx
Hello everyone!
I'm in high school and attempting to build a ruben's tube.
I am on a very strict budget and came across free brass tubing, but the diameter is 1 inch.
All the tutorials I've seen use a diameter of at least 2inches if not more.
Will a pipe with a one inch diameter work? (at least in theory?) Or is there a real physical sciency reason that there must be a 2inch diameter.
I appreciate all the help!
I see no reason why not, the wave effect might be diminished slightly or you might get some distortion from the waves bouncing a little bit, but nothing that should make the final waveform difficult to see.
I'm going to do it with a 2" ID pipe at some point, so I'll see how it works if I ever get around to finishing the project.
Post some video when it's done!
(Oh yeah, you should try to light it with a tesla coil :p)
There could be two issues with a smaller dameter tube.
1. The gas flow velocity along the tube will be higher, assuming the same length of tube and the same size and number of holes. That might distort the standing waves a bit.
2. The resonance peaks won't be as sharp for a narrower tube. The energy loss in the gas will be mainly the boundary layer around the surface of the tube. The mass of vibrating gas is proportional to ##r^2## and the surface area is proportional to ##r##, so the amount of damping is relatively less for a wider tube.
But I don't know idea how much effect those things will have - the best way to find out would be make one and try it.
Hm, okay, so basically just perhaps the waves won't be so clear.
Yeah, I guess the best way will be to try it. I just wanted see if anyone has ever actually done or there is an actual reason so I don't waste my time.
Also, I am realizing that it'll be harder to get the holes exactly perpendicular.
I thank you all a lot for your help!
I have been trying to create a Rubens' tube with 1" black pipe myself;
due to weight & cost considerations. Thus far I have qualified success.
Currently I am only able to get a bass response near the end with the
speaker, no sinuous wave forms to speak of.
My holes are 1/16", and 1/2" apart along 4.5' of a 5' length of pipe.
I am using a helium-quality latex balloon stretched taught over the end
opposite the gas inlet, held on with a hose clamp. I have tried a plain
membrane, and one with a small disc of paperboard attached, as
recommended by some tutorials. The membrane with disc seemed to
provide a larger response to the speaker, but overall the results are
disappointing. Only about 5 inches of the 5 foot pipe are noticeably
reactive to the sound.
Any thoughts regarding troubleshooting?
P.S. I found that a standard low-pressure regulator was insufficient,
the last 15 inches of pipe had no flame. I special ordered an
adjustable high pressure regulator, and can now get all holes to light.
The adjustment also provides some control over flame height, although
much larger than 2 inches and the flames become a bit erratic.
I have no experience with use of reuben's tubes but 'm in the process of building a 24" er with 20" of 1/16" holes, 1" at centers. 1/2" seems a little close to me.
1/2 inch is what I saw in many tutorials, although it varies up to 2cm or 1 inch.
The proximity is so that they are close enough to relight one another if any
particular jet goes out. From experience thus far, that seems about right.
When the end gets blown out, flames reignite one jet at a time with noticeable delay.
I don't see how this should affect sound propagation, but I might try taping
up alternating holes with aluminum duct sealant tape...
  • · Replies 19 ·
11K
  • · Replies 25 ·
