Causal signals and causal system
  • Thread starter Thread starter reddvoid
    Signals System
The discussion clarifies the distinction between causal signals and causal systems. A causal system, defined by its output depending solely on present and past inputs, is confirmed to be causal. In contrast, a signal that exists from negative infinity to positive infinity is classified as non-causal. The conversation emphasizes that causality in systems is more meaningful than in signals, as causality in signals pertains to their values relative to time t=0, with causal signals being zero for t<0, while non-causal signals have values for t<0.
  • Understanding of causal systems in signal processing
  • Knowledge of signal classification (causal, non-causal, anti-causal)
  • Familiarity with time-domain analysis of signals
  • Basic concepts of input-output relationships in systems
  • Research the properties of causal systems in signal processing
  • Explore the implications of non-causal signals in real-world applications
  • Learn about time-shifting and its effects on signal causality
  • Investigate the mathematical definitions of causal and non-causal signals
Students and professionals in electrical engineering, signal processing specialists, and anyone interested in the theoretical foundations of causality in systems and signals.
reddvoid
Is there a difference between causal signal and causal system ?
I got this doubt because
consider a system h(t) whose out put depends on present and past inputs only for all t (- infinity to + infinity ) so this system is a causal system
now if we treat this as a signal and since it exists from -infinity to+ infinity so it will be a non-causal signal. . . .
which one is correct ?
Causality in systems makes the most sense. Causality in signals doesn't make that much sense.
Causality in systems determines whether a system relies on future information of a signal x[n+1].
When talking about "causality" in signals, we mean whether they are zero to the left of t=0 or zero to the right of t=0.
A causal signal is zero for t<0
A non-causal zero has values present for t<0.
Anti-causal signals are zero for t>0.
However, the reason why this doesn't really make sense is that if you have a signal, the time t=0 can be chosen arbitrarily.
Got it :) thank you for clarifying :)
  • · Replies 456 ·
32K
  • · Replies 0 ·
