How Do Coherence and Entanglement Affect Photon Interference?
  • Context: Graduate
  • Thread starter Thread starter San K
    Entanglement
This discussion centers on the relationship between coherence, entanglement, and photon interference. It establishes that incoherent photons can still exhibit interference effects, although the patterns may not be clear. The coherence of light increases when passed through a pinhole due to the selection of specific light properties. Additionally, while coherence can be modified in entangled photon pairs, the wave functions in a single particle double-slit experiment are treated as a single entity rather than being entangled with each other.
  • Understanding of quantum mechanics principles
  • Familiarity with photon behavior and interference patterns
  • Knowledge of coherence and entanglement concepts
  • Basic grasp of experimental setups in quantum optics
  • Explore the concept of "incoherent photons" in quantum optics
  • Research the effects of pinhole diffraction on light coherence
  • Investigate methods for manipulating entanglement in photon pairs
  • Study the implications of wave function behavior in double-slit experiments
Quantum physicists, optical engineers, and researchers interested in the fundamental principles of light behavior and quantum entanglement.
San K
Trying to understand coherence and entanglement and have some questions:
1. Do incoherent photons interfere?
a) Single particle interference through double slit
b) Multiple photons through double slit
Is it that the interference pattern in the above cases is not a clear fringe pattern however there is still interference?
2. Why does coherence increase when light is passed through a pin hole?
3. Why does brighter light have higher coherence?
4. What does coherence within a single photon mean?
5. Can coherence be changed (is it reversible) within the same photon?
i.e. Is entanglement changeable between two photons?
i.e. can the experimenter play with coherence and entanglement with the same set of entangled photons?
i.e. decrease coherence and watch the effect of increased entanglement, Increase coherence and watch the effect of decreased entanglement?
6. In a single particle, double -slit experiment are the wave-functions passing through each slit assumed to be entangled with each other? in the case of an "in-coherent" photon?
What do you mean with "incoherent photons"?
There are no photons you can point to and say "this cannot have interference".
You can get interference effects with all light, but if the different photons in that light are not coherent (to each other!), you might be unable to notice this.
Depends on the setup. You select some specific part of your light, which might have some special properties (with the obvious one: "went through that hole").
This is not a general rule. It might depend on the setup.
What do you mean with that?
You can transfer entanglement between different photon pairs, and modify the entangled properties. If that does not answer your question, I don't understand it.
It is a single wave function.
  • · Replies 24 ·
  • · Replies 19 ·
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 41 ·
