Proving an Inequality for All n: x1n+...+xnn≥nx1...xn
  • Context: Undergrad
  • Thread starter Thread starter johnqwertyful
    Inequality
The discussion revolves around proving the inequality x1^n + ... + xn^n ≥ n*x1...xn for all positive x, with a focus on extending the proof from n=3 to all n. Participants explore various mathematical approaches, including induction and the generalized mean inequality.
  • One participant claims to have proven the inequality for n=3 but struggles to extend it to all n, suggesting induction as a possible method.
  • Another participant identifies the inequality as a special case of the generalized mean inequality, emphasizing the need to separate the number of variables from the index.
  • Concerns are raised about the requirement for the x's to be greater than or equal to 1, with examples provided that challenge the inequality under certain conditions.
  • A participant discusses the importance of understanding how the constant n is used in the inequality and provides specific examples with chosen values for x.
  • Further clarification is sought regarding the relationship between the powers and the number of terms in the inequality.
  • One participant introduces Jensen's inequality as a more general framework that encompasses the original inequality, suggesting a connection to logarithmic functions.
  • Another participant explores the implications of using different powers in the inequality and how it affects the formulation.
  • Overall, participants express appreciation for the insights shared, indicating the discussion has been helpful in understanding the inequality.
Participants express differing views on the conditions under which the inequality holds, particularly regarding the values of x. There is no consensus on the necessity of the x's being greater than or equal to 1, and the discussion remains unresolved on several points.
Some participants note the ambiguity in the original post regarding whether the right-hand side is a sum or a product, which affects the interpretation of the inequality. Additionally, the discussion highlights the need for clarity in the definitions and assumptions used in the inequality.
johnqwertyful
I have proven to n=3 an inequality that seems useful. x1n+...+xnn≥nx1...xn for all positive x.
I'm sure this has been proven before. I'm not quite sure how to extend it from n=3 to for all n. I'm thinking induction, but that has proven challenging. Any hints?
Mathematics news on Phys.org
This is a special case of the generalised mean inequality. You have coupled the number of variables with the index, they should be separate. Then you want to show that the mean is monotonically increasing in the index.
Don't you require the x's to be >= 1 ? For example, 0.1^2 + 0.2^2 + 0.3^2 < 2*(0.1 + 0.2 + 0.3).
(I assume that, on the right-hand side, n multiplies the whole sum, which is not clear in the OP.)
P.S.: Actually, also 1.1^3 + 1.2^3 + 1.3^3 < 3*(1.1 + 1.2 + 1.3). So I'm at a bit of a loss.
The RHS isn't a sum, it's a product.
Ah... thanks, Mentallic.
Still, 10^3 + 11^3 + 12^3 + 13^3 < 3*10*11*12*13 < 4*10*11*12*13.
(Not sure yet if the RHS multiplier is to be the power or the number of terms - though I can't find a counterexample if both are actually coupled.)
Take careful notice of where the constant n is used in the inequality:
[tex]x_1^n+x_2^n+...+x_{n-1}^n+x_n^n \geq n\cdot x_1x_2...x_{n-1}x_n[/tex]
So what this means you should do is to take some value n, say, n=4, and now you need to choose 4 real positive numbers because we need to assign a value to [itex]x_1,x_2,x_3,x_4[/itex] since the inequality tells us to go up to [itex]x_n=x_4[/itex].
So if we used [itex]x_1 = 5, x_2 = 6, x_3 = 20, x_4 = 31[/itex] then we'd have
[tex]5^4+6^4+20^4+31^4 \geq 4\cdot 5\cdot 6\cdot 20\cdot 31[/tex]
If we used n=10 then we'd need to go up to [itex]x_{10}[/itex] and the LHS will use powers of 10.
This would work if you had
[tex]10^4+11^4+12^4+13^4 \geq 4\cdot 10\cdot 11\cdot 12\cdot 13[/tex]
Don't sweat making the mistake though, all these [itex]x_n[/itex]'s can be quite daunting at first sight, and unless they were clearly explained to you which it doesn't seem like they were, you're going to have a tough time guessing what they mean.
At least, I know I used to!
Ah, thanks again. Then the power and the number of terms *need* to be coupled. Using the namings in the wiki page for the generalized mean inequality,[tex]M_0(x_1,x_2,...,x_n) \le M_n(x_1,x_2,...,x_n)[/tex] because 0 < n. Then raise each side to the n-th power to remove the n-th roots.
Though I can't say I understand the inequality, or know how to prove it, being the first time I see it. :)
So in general, if [itex]w_1,...,w_n\in [0,1][/itex] with [itex]w_1+...+w_n=1[/itex], then we have
[tex]x_1^{n\cdot w_1}\cdot ...\cdot x_n^{n\cdot w_n} \leq w_1x_1^n + ... + w_nx_n^n[/tex]
The original inequality has [itex]w_i=1/n[/itex].
Even more general, we have Jensen's inequality that states that for any function [itex]\varphi:(0,+\infty)\rightarrow \mathbb{R}[/itex] such that [itex]\varphi^{\prime\prime}(t)\leq 0[/itex] for all t, then
[tex]w_1\varphi(y_1)+...+w_n\varphi(y_n)\leq \varphi\left(w_1y_1 + ... + w_ny_n\right)[/tex]
The original inequlaity follows with [itex]\varphi = \log[/itex] and [itex]y_i = x_i^n[/itex].
Ah, I see... if, with weights [itex]w_i = 1/n[/itex] you were to choose an arbitrary power, say [itex]y_i = x_i^k[/itex], then in order to make [itex]\sqrt[n]{x_1^k x_2^k x_3^k ...} = x_1 x_2 x_3 ...[/itex] at that point is where you would need [itex]k=n[/itex].
in other words, with a different power the inequality would look like[tex]x_1^k + x_2^k + ... + x_n^k \ge n \sqrt[n]{x_1^k x_2^k ... x_n^k}[/tex]
Thanks for a very informative post, micromass... (but now I have a lot to read :)
Wow, this has been an extremely helpful thread. Thanks everyone! I knew I wasn't the first to think of this. It's definitely a useful inequality.
I really appreciate the help, I'll look over the wiki page.
  • · Replies 35 ·
  • · Replies 0 ·
