Calculating the magnetic field in solenoid
The magnetic field in a solenoid can be calculated using the formula B = μnI, where n is the turn density defined as N/L, I is the current, and μ is the permeability of the material. When using a steel core, the length L should refer to the length of the core that is surrounded by the coil, not the actual length of the coil itself. This distinction is crucial as it affects the calculation of magnetic flux, which remains consistent regardless of turn density. Therefore, for accurate calculations, L must represent the length of the core.
  • Understanding of magnetic field calculations
  • Familiarity with solenoid theory
  • Knowledge of permeability in materials
  • Basic electrical concepts, including current and turn density
  • Study the effects of different core materials on magnetic field strength
  • Explore advanced solenoid design techniques for optimizing magnetic fields
  • Learn about the relationship between coil geometry and magnetic flux
  • Investigate the applications of solenoids in electromagnetic devices
Physicists, electrical engineers, and students studying electromagnetism who seek to deepen their understanding of solenoid behavior and magnetic field calculations.
rp8308
Just need a question cleared up.
If I had a coil wrapped around a core, and I was calculating the magnetic field of the solenoid using
B = μnI
where n = N/L, I is current and μ is the permeability of my material
N being the number of turns in the coil, and L being the length of the solenoid if there was an air core. Now if I had a steel core, for example, and the core was a large circular shape such that the coil itself only wrapped around a small amount of the core. Would the length L be the length of the solenoid still? (because its defined as turn density) or would it be the length that the magnetic flux takes through the whole core and therefore be the mean length of the core? (much larger than the length of the solenoid).
Cheers
ok I am pretty sure its the length of core because flux through the core won't change with the density of turns, but could do with someone just confirming this... I hate when i confuse myself
If you meant to say L is the length of the coil, then yes I agree.
Edit: By 'length of the coil' I mean the length of the core which is surrounded by coil. (Not the actual length of the coil which is wrapping around it).
  • · Replies 21 ·
