Basic questions about signal processing and fourier analysis
The discussion centers on the relationship between fundamental frequencies and harmonics in signal processing and Fourier analysis. It establishes that while the fundamental frequency is typically the peak frequency, this is not an absolute rule. The first frequency in a harmonic series is confirmed to be the fundamental frequency. Additionally, frequency tables, such as those listing C3 at approximately 63.5 Hz, refer specifically to the fundamental frequency of the note.
  • Understanding of fundamental frequencies and harmonics
  • Familiarity with Fourier analysis concepts
  • Knowledge of sound wave properties
  • Basic interpretation of frequency tables
  • Explore the concept of harmonics in depth
  • Learn about Fourier Transform and its applications
  • Study the relationship between frequency and sound perception
  • Investigate different frequency tables for various musical notes
Musicians, audio engineers, sound designers, and students of signal processing seeking to deepen their understanding of frequency relationships in sound.
hale2bopp
1)A note consists of a fundamental frequency and the multiples of that frequency called harmonics. Peak frequency means that one that contributes most to the note. Is the fundamental frequency always the peak frequency? Since the frequencies die out very quickly as the value of n increases, where n is the factor that multiples the fundamental, shouldn't the fundamental always have the highest peak?
2)Is the first frequency always the fundamental?
3)When looking up frequency tables, there are specific numbers given for each note eg C3 has 63.5 Hz approx. What does this refer to? The peak, the fundamental, or some other value altogether?
Thanks!
I assume you are asking about sound.
1) Most likely, but not always.
2) Yes.
3) Table will give value for fundamental.
