Magnetic field directionality, mathematic rigmarole?
The discussion centers on the relationship between the direction of magnetic fields and the forces exerted on moving charged particles. It highlights that the force experienced by a charged particle in a magnetic field is always perpendicular to both the velocity of the particle and the magnetic field itself, as described by the equation F.b=q(vXB). The question raised is whether the directionality of the magnetic field is merely a definitional construct or if it has a tangible basis in reality that can be experimentally validated. It is noted that the magnitude and direction of the magnetic force depend on the particle's speed and trajectory, leading to different forces for particles moving through the same point in different directions. Consequently, a unique magnetic field cannot be defined at a point that aligns with the magnetic force experienced by the particle.
Phyzwizz
The force as a result of a moving charged particle through a magnetic field is perpendicular to the field apparently. Why should the magnetic field be perpendicular to the force created as a result. F.b=q(vXB) is the mathematical notation for this which accurately describes the world. But I cannot imagine why it would be impossible for math to describe the magnetic force instead in terms of a magnetic field that is parallel with it. So is the directionality of the magnetic field, simply just assigned by definition, or does it have some basis in reality that can actually be proven by experiment?
Both the magnitude and direction of the magnetic force on a particle moving through a particular point in space (with a given surrounding arrangement of currents and/or moving charges) depend on the particle's speed and direction of motion. Two particles going through the same point with the same speed but in different directions, experience magnetic forces that (in general) have different magnitudes and directions. Therefore one cannot define a unique magnetic field at that point that has the same direction as the magnetic force.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
