Pen ink faded off upon heat(or maybe sunlight)
  • Thread starter Thread starter coconut62
    Ink Sunlight
The discussion centers around the phenomenon of pen ink fading when exposed to heat or sunlight, particularly focusing on the composition of the ink and the mechanisms behind its decoloration. Participants explore various hypotheses regarding the chemical properties of the ink and its interaction with environmental factors.
  • One participant describes their experience of ink disappearing from their math exercises after leaving the books in a car, questioning the composition of the ink that allows it to fade under heat.
  • Another participant suggests that the ink may not have evaporated but rather decomposed, possibly reacting with paper compounds or oxygen, and that heat could accelerate this process.
  • A question is raised about the potential effects of having the pen and books in close proximity, prompting speculation about chemical interactions.
  • One participant proposes that if the compound causing decoloration is volatile and the pen was heated, vapors could affect the ink on the paper, although they express doubt about this scenario.
  • Another participant explains that the ink is designed to fade with heat from friction erasing, suggesting that it becomes transparent rather than being completely removed, and mentions that freezing the notes might restore the ink.
  • A later reply confirms that applying heat can cause the ink to fade and discusses the temporary nature of the ink's visibility when heat is applied, indicating that prolonged exposure may lead to permanent transparency.
  • One participant suggests a simple experiment of placing the paper in the freezer to test if the ink color reappears.
Participants express various hypotheses regarding the fading of the ink, with no consensus on the exact mechanisms or the role of heat and chemical reactions. Multiple competing views remain regarding the nature of the ink and its interaction with environmental factors.
Participants discuss assumptions about the ink's chemical properties and the conditions under which it fades, but these remain unresolved. The discussion does not clarify the specific chemical composition of the ink or the exact processes involved.
coconut62
Last month I bought one of those pens which you can rub off your writings with a kind of rubber at the end of the pen. I was so happy because I don't need to use correction pens anymore, so I did all of my maths exercises with that pen. One Friday, my books was very heavy so i left some inside the car. On monday when I take it to school, open it, I discovered in horror that all my writings has GONE. Some of them already became transparent, while some of them were still fading off. I was like wtf man, how can you be like this? Evaporated just because of a little sun? In the end, I have to redo all my exercises.
Can someone tell me what is the composition of that pen ink which makes it evaporate under heat? And my maths papers were not directly exposed to sunlight, it was at the bottom of one or two books and I kept them all in those plastic clear holders.
Seriously what kind of witchcraft is this? Monster it is. :mad:
Chemistry news on Phys.org
Adds a new twist to "dog ate my homework", doesn't it?
I don't think it "evaporated", more like the dye decomposed, perhaps by reacting with some of the paper compounds or air oxygen. If it was heated, such process should speed up, even several times (which can mean all your notes will disappear eventually even without heating).
There are also other possibilities - were your books lying close to something? Pen itself?
What would *possibly* happen if my books were lying right beside my pen?
Very unlikely, but IF the compound responsible for decoloration is volatile, and IF the pen was heated, some of the vapors could penetrate into your notes and react with the dye in the ink. I have reasons to doubt that's what have happened, still, I can't rule that 100% out.
The ink was formulated to fade with the heat of friction erasing produces! It never is really removed when you 'erase'. It just becomes transparent. It should reappear when exposed to something like -14F. Sounds like freezing your notes will make them reappear. I wonder if your freezer gets that cold...
Sounds like some funky liquid crystal technology.
I don't understand your logic, do you mean that the compound responsible for decoloration is INSIDE the pen? And the pen is making its own ink decolorise? :confused:To CHEMISTTREE:
YES. I wrote a few words on a paper with it and then I put the paper under a hairdryer. After a few seconds, the ink faded off. I quickly removed the paper and it magically reappeared. But after I applied heat for a longer time, it never reappeared again. I think they became transparent permanently, just like my homework :frown:
Try putting it in the freezer and see if the ink color reappears. Cheap test, no?
  • · Replies 31 ·
