What is the area, in sq. feet, of the debris?
  • Context: Undergrad
  • Thread starter Thread starter alyhandra3
    Project
The discussion centers on calculating the area of a debris field formed by colliding rockets, represented by a 3D parabola with a vertex at (927499.96478, 359333.803) and a scale factor of -1.5. The equation for the parabola is expressed in the form y = a(x - x0)² + y0, where 'a' is the scale factor. To determine the area of the debris, one must first find the intersection of the parabola with the ground, which results in a circular area. The height above the ground is critical for calculating the radius of the resulting circle.
  • Understanding of parabolic equations and their forms, specifically y = a(x - x0)² + y0.
  • Knowledge of 3D geometry and how parabolas interact with planes.
  • Familiarity with the concept of area calculation for circles.
  • Basic algebra skills for solving quadratic equations.
  • Study the properties of parabolas, focusing on their vertex and scale factors.
  • Learn how to derive the intersection points of 3D shapes with planes.
  • Research methods for calculating the area of circles based on radius.
  • Explore practical applications of parabolic trajectories in physics and engineering.
Students in physics or mathematics, engineers working with projectile motion, and anyone involved in modeling trajectories or calculating areas of geometric shapes.
alyhandra3
hello, I need to finish these questions by tomorrow for a project and I have no idea on how to do them due to my absences in the class because of illness. If anybody could provide help, that'd be greatly appreciated.
5. if the rockets collide at F, then the rockets will create a debris field that forms a parabola with vertex at F and scale factor of -1.5. Write the equation for parabola in y=ax^2=bx=c form.
(F as a vertex point is 927499.96478,359333.803
6. The parabola formed by the debris field is actually 3D. When a 3D parabola hits a plane like the land, then the intersection is a circle. What is the area, in sq. feet, of the debris?
Thanks for any and all help
in regards to question 5 i misstyped some of the info..the equation is y=ax^2+bx+c..and the vertex is (27499.96478, 359333.803)
What you apparently missed from class is that the equation of a parabola, with vertical axis and vertex at (x0,y0), can be written y=a(x- x0)2+ y0. a is what you are calling the "scale" factor: -1.5 (negative because the parabola "opens" downward. Just plug the numbers you are given into that.
It's impossible to answer 6 because you haven't told us what the coordinates of the vertex MEAN. If we ASSUME that the y component is the height above the ground, then the debris will hit the ground when y=a(x- x0)2+ y0= 0. You don't really need to solve for x- what you want to know is x- x0- how far away, horizontally, from the vertex the debris hit. That is the radius of the circle.
  • · Replies 21 ·
  • Poll Poll
  • · Replies 17 ·
