How can you optimize turning over seven hexagonal mats in the fewest moves?
  • Thread starter Thread starter Natasha1
    Puzzle
The minimum number of moves required to turn over seven hexagonal mats, when turning three at a time, is three. The sequence of moves is represented as +3 + (2 - 1) + 3, totaling seven. It is established that turning an odd number of mats with an even number of moves results in a pattern where only even totals can be achieved. Further exploration into different total numbers of mats, such as five to thirteen, is necessary to identify consistent patterns in the number of moves required.
  • Understanding of combinatorial game theory
  • Familiarity with basic arithmetic operations
  • Knowledge of patterns in number sequences
  • Introduction to modulo arithmetic
  • Investigate combinatorial strategies for turning over mats
  • Explore the implications of modulo arithmetic in game theory
  • Analyze patterns in sequences of moves for different numbers of mats
  • Examine the mathematical principles behind odd and even number manipulations
Mathematicians, puzzle enthusiasts, game theorists, and educators looking to deepen their understanding of combinatorial optimization and number patterns.
Natasha1
Here my problem to solve: (Could anyone share some insight?)
You have seven hexagonal-shaped mats in a line. These mats all have to be turned over, but you can only turn over exactly three at a time.
You can choose the three from anywhere in the line.
A mat may be turned over on one move and turned back over again on another.
What is the smallest number of moves you can do this in?
Try with other numbers of mats.
Do you notice any patterns in your findings?
Can you explain why these patterns occur?
Here is my answer so far:
So the minimum number of turns for 7 cards, turning 3 at a time is 3 as follows:
+ 3 + ( 2 – 1) + 3 = 7
You always start and end with the number you are turning, so in the above you start with a +3 and end with a +3, so you just need to add another one (2-1) to make 7.
From here you can conclude that it is impossible to do if you have an odd number of cards and an even number of cards to turn e.g. if you are turning 6 cards at a time the only numbers you can make are even as follows:
+ 6
( 5 - 1) = 4
( 4 – 2) = 2
( 3 – 3) = 0 (pointless)
( 2 – 4) = 2
( 1 – 5) = 4
- 6
I don't know why you did the stuff with turning 6 cards at a time. It asks you to investigate what happens when you have a different total number of mats to turn over, not when you have a different number of mats to turn over at a time. Figure out how many moves it takes to turn over 5, 6, 7, 8, 9, 10, 11, 12, or 13 mats, given that you must turn over 3 at a time. Once you figure out 5-10, then figuring out 11-13 should be a no-brainer, and you should have fully understood the pattern.
This statement...
...nevertheless, is true.
Have you studied any modulo arithmetic yet ?
  • · Replies 29 ·
