Why aren't electrons considered black holes ?
The discussion revolves around the question of why electrons are not classified as black holes despite having mass, which theoretically suggests there could be a distance where their escape velocity exceeds the speed of light. Participants explore the implications of this idea within the realms of classical physics, quantum mechanics, and theoretical models.
  • Some participants suggest that electrons should be considered tiny black holes due to their mass and the concept of escape velocity.
  • Others argue that the distance at which this escape velocity would be relevant is so small that it becomes practically meaningless.
  • A participant notes that modeling an electron as a charged sphere leads to breakdowns in theoretical predictions.
  • There is mention of scattering experiments supporting the idea of the electron as a point particle, raising questions about the necessity of a quantum theory of gravity for a definitive answer regarding its black hole status.
  • Some physicists have proposed modeling the electron as a Kerr-Newman black hole, which could theoretically yield the correct gyromagnetic ratio, but this model would not actually result in a black hole due to the absence of an event horizon.
  • One participant speculates that electrons could be considered naked singularities, while another challenges this notion by referencing calculations that suggest electrons are far from being classified as such.
  • Concerns are raised about the validity of external articles discussing the electron's nature, with some participants expressing skepticism about their claims and the reliability of their sources.
  • Discussions also touch on the limitations of current physics in high-energy regimes and the concept of effective field theories in both quantum mechanics and gravity.
Participants express a range of views on the classification of electrons, with no consensus reached. Some support the idea of electrons as black holes or singularities, while others challenge these notions and highlight the complexities involved in modeling fundamental particles.
Participants acknowledge the limitations of current theories and the unresolved nature of high-energy physics, particularly regarding the behavior of particles at very small scales. There is also a recognition of the challenges in extending existing theories into these regimes.
Quaoar
Why aren't electrons considered "black holes"?
They have mass, so there should be a distance that's close enough to the electron where the escape velocity is greater than the speed of light. So, therefore, shouldn't electrons (and all other fundamental particles with mass) be considered tiny little black holes?
Well, if you calculate what that distance is, you'll probably find it to be so small as to be meaningless. Below a certain distance and you're smaller than the smallest wavelengths of EM radiation.
There are a lot of questions about electrons that remain unanswered to this day. For example, when you try to model an electron as a tiny charged sphere, things break down. For my part, I just don't go there!
Results of scattering experiments are consistent with the electron being a point particle, so is an electron a black hole? This very interesting question probably requires a quantum theory of gravity for a definitive answer.
Some physicists have modeled an electon with a Kerr-Newman (i.e., charged and spinning) black hole, and I think this gives the correct g = 2 gyromagnetic ratio.
Examples of possible problems with quantum theory:
What if the electron wavefunction is non-zero outside the event horizon?
Hawking radiation from an electron black hole?
Uncertainty principle does not allow?
All right - who's going to step up to the plate and supply the required quantum theory of gravity?
These would be good questions for Mr. Sweetser whose work is in the Independent Research forum. What does his model predict?
Well, classically it all depends on what radius you attribute to the electron, if it is not to be treated as a point charge.
Throwing in some numbers to get an OOM feel for the question we find:
Classical radius of electron = 2.8 x 10-13 cm
Reduced mass of electron in H atom = 9.1 x 10-27 gm
G = 6.7 x 10-8 dyn cm2gm-2
c2 ~ 1021 cm2 sec-2
[tex]\frac{2GM}{rc^2}[/tex] = 4.8 x 10-43,
pretty short of the value "1" required for an event horizon...
Garth
I'll write a more complete reply on the Independent Research forum where it belongs, but the answer is both simple and kind of general: if a theory of gravity is found that is consistent with quantum mechanics and is not the rank 2 field equations for gravity found in general relativity, in that case all the work done on black holes will disappear into a black hole of its own, never to reappear because the papers are not relevant to the description of Nature.
doug
Misner, Thorne, and Wheeler points this out (with an exclamation mark!) on page 883.
However, a Kerr-Newman solution with the physical parameters of an electron would not actually be a black hole, as it has no event horizons.
IIRC Wheeler once suggested that an electron-positron pair (and other particle/anti particle pairs for that matter) could be the two ends of a wormhole. I think there are some problems with this idea - one that comes to mind is that it doesn't work so well unless every particle has an antiparticle, which is currently not felt to be the case.
I have always thought. Maybe electrons ARE naked singularities?
Are you not 43 OOM out? - see my post #6.
And why should they be naked?
Garth
I think the Black Hole question is because of a "point particle" concept. I've never thought of an electron as a point particle myself so I thought I'd have a look on google. I found this. It looks interesting, but I'm not sure what I can trust on the internet these days. Garth, pervect, do you know if this article is truthful and reasonable? Is it common sense?
http://www.commonsensescience.org/contradictions.html
"The point electron used for convenience has additional problems called a "mystery" by Sellin. Concentration of the electron charge in a point would require an infinite amount of energy and an infinite force to balance the outward directed Coulomb Force. If the rest mass energy is infinite, then the equivalent mass (M) equal to energy (E) divided by the light velocity (c) squared must (by modern theory) also be infinite. But the rest mass of an electron has been measured, and it is not infinite..."
That site looks fishy to me.
We have physics that work very well in the energy region accessible to us - even the most powerful colliders we have been able to build.
However, it is known that there are problems with extending this physics too far into high energies - or equivalently, at distances that are too close. (It takes a very high energy to get electrons that close to each other).
This is an area that I'm not as familiar with as I would like, but the Wikipedia article:
http://en.wikipedia.org/wiki/Landau_pole
points out there are problems even in QED, at high enough energies.
So what we have, currently, is known as an "effective field theory".
This is perhaps more obvious for gravity, see for instance
http://arxiv.org/abs/gr-qc/9512024
which is about quantum gravity as such an effective field theory. But gravity is (apparently, anyway) not alone in being in the "effective field theory" boat.
Farsight, your article is neither truthful nor reasonable. It misrepresents the current picture of particle physics and makes unsubstantiated claims about an unexplained "theory."
By my count, this article rates a 129 on the Crackpot Index.
Also their should be points for saying that the bible supports your theory.
"Earliest Model of the Atom?
The first chapter of Ezekiel’s book found in the Bible seems to describe rings in a way that is consistent with the most general features of atomic structure. The four rings described by Ezekiel have the same physical arrangement and orientations as the rings found in the Lucas model of the atom. The most important feature of the atom is its stability, a feature emphasized by Ezekiel for his rings. The hydrogen gas molecule consisting of two electrons and two protons is the most simple and abundant form of matter in the universe; and in the Lucas model, diatomic hydrogen gas “looks” just like the four rings described by Ezekiel."
G01 said:
Nice!:smile:
20 points for naming something after yourself. (E.g., talking about the "The Evans Field Equation" when your name happens to be Evans.)
Did you add in the points from this?
Lucas Model of the Atom
“In 1996, while still a high school student, Joseph Lucas introduced his model of the atom. In this model, electrons, protons and neutrons are all based on Bergman's Spinning Charged Ring Model of Elementary Particles (a refinement of Parson's Magneton). The Lucas Model of the Atom is by far the most successful of all models of the atom ever proposed. It is a physical model that shows where electrons are located throughout the volume of the atoms. This model predicts the "magic numbers" 2, 8, 18, and 32 of electrons in the filled shells and also is able to predict why the Periodic Table of the Elements has exactly seven rows. The Lucas model also predicts the structure of the nucleus and correctly predicts hundreds of nuclide spins.
Hmmm...
I was only counting on the one page. But, that would certainly count.
Of course, if I wanted to cover the whole site, I'd have to go through the papers they have posted. But, I don't really want to spend money to read crackpottery (or, should that be cracked pottery?). I suppose it's possible that they actually have something worth looking at in those papers (and would lose the 50 points for lack of concrete, testable predictions); but I doubt it, particularly since only one of their papers seems to have been printed anywhere and it was in a Creation Science journal.
There probably should be points for that, but the index doesn't seem to cover it. I wonder if Baez is open to suggestions for an expanded index.
Points for being crackpot? As a theologian as well as a scientist I can confidently state that the above isn't even crackpot; it is complete lunacy.
Garth
Thanks for the feedback guys.
One more thing
Just stumbled onto this thread. Garth's calculation is correct; the event horizon is 2GM/c^2 away from the center of a body, which must be > r in order for the calcuations to be valid and an event horizon to exist.
I wanted to point out that there are a few unknowns working here as well. For one thing, classical general relativity doesn't take quantum effects into account, so cannot be used at length scales this small. Secondly, as far as I know, the basic structure of an electron (or any fundamental particle) isn't known. The point particle model works only at scales >> than the "radius" of the electron. If one believes string theory, then an electron is a 1-D vibrating string and the question is moot.
  • · Replies 16 ·
  • · Replies 40 ·
  • · Replies 23 ·
  • · Replies 51 ·
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 39 ·
