Need to convert 110v to 220v from 110 v inverter
  • Thread starter Thread starter saad ahmed khan
    Convert Inverter
The discussion centers on converting 110V to 220V using a 200W DC to AC inverter from Black & Decker. The user seeks a transformer capable of this conversion but encounters difficulties finding one, as local shops primarily offer transformers that convert 220V to 110V. It is confirmed that transformers can operate in reverse, but the existing setup may require rewiring by a qualified individual to achieve the desired output configuration.
  • Understanding of AC to DC inverter functionality
  • Knowledge of transformer operation and wiring
  • Familiarity with electrical safety standards
  • Basic electrical engineering concepts
  • Research how to safely rewire a transformer for reverse operation
  • Learn about electrical safety protocols when working with high voltage
  • Investigate the specifications and limitations of Black & Decker inverters
  • Explore the differences between step-up and step-down transformers
Individuals looking to convert voltage for appliances, electricians, DIY enthusiasts, and anyone involved in electrical installations or modifications.
saad ahmed khan
hello every one
i just got a dc ac inverter 200w at 110v from black&decker company
which my uncle sent me
problem is all appliances here are rated at 220v-230v
so i went to look for the transformer that could convert 110v to 220v
but all the shop keepers tell me that the only transformer they have is one that converts 220 v to 110 v for 110v appliances.
i find this a bit strange can't the transformer be used in reverse.
i know for a fact that if i give 12v ac to a 220v to 12v transformer from the 12v side i get 220 v ac output
i just wnt to make sure that the same can be donne with a 110v 220v transformer before i buy it
thanks to alll
The transformer itself will do the job in reverse, but it sounds like it is wired into a box with a 220 volt input plug and a 120 volt output socket. Maybe a qualified individual could wire it with a 120 volt plug and a 220 volt socket output.
  • · Replies 26 ·
  • · Replies 136 ·
21K
29K
  • · Replies 17 ·
32K
  • · Replies 16 ·
17K
