Introducing LaTeX Math Typesetting
The discussion centers around the introduction of LaTeX mathematical typesetting on Physics Forums, focusing on its implementation, usage, and examples. Participants explore how to effectively use LaTeX for mathematical expressions and share examples of LaTeX code.
  • Homework-related
  • Warren introduces LaTeX typesetting, explaining its markup style and how to include LaTeX graphics in posts.
  • Some participants share additional examples of LaTeX code, demonstrating various mathematical expressions.
  • Warren invites suggestions for LaTeX packages to include, expressing concern about performance impacts from too many packages.
  • One participant inquires about using the LaTeX generator for personal web pages, prompting a discussion about server load and intended use.
  • Another participant expresses enthusiasm for practicing LaTeX by writing equations related to particle interactions.
  • A question arises about formatting subscripts in LaTeX, specifically how to create multi-line subscripts.
  • Participants provide tips on learning LaTeX, including quoting existing code to see how it is written and encouraging practice.
  • Warren reminds participants that clicking on LaTeX images reveals the source code, which can aid in learning.
Participants generally agree on the usefulness of LaTeX for typesetting mathematics, but there are differing views on its application for personal use outside the forum, with some cautioning against it due to resource concerns.
Some participants express uncertainty about specific LaTeX formatting techniques and the potential performance implications of adding more packages to the forum's LaTeX capabilities.
  • #691
Thanks rob!
~H
  • #692
[tex]\Theta=15 \cdot \frac {\pi}{180}=\frac {3\pi}{16}[/tex]
  • #693
Testing;
[tex]{\color{red}\boxed{{\color{blue}\frac{dy}{dx} = \frac{\frac{dy}{dt}}{\frac{dx}{dt}}}}}[/tex]
  • #694
[tex] \setlength{\unitlength}{1mm}<br /> \begin{picture}(60, 40)<br /> {\color{red}\put(30, 20){\vector(1, 0){30}}}<br /> {\color{orange}\put(30, 20){\vector(4, 1){20}}}<br /> {\color{yellow}\put(30, 20){\vector(3, 1){25}}}<br /> {\color{green}\put(30, 20){\vector(2, 1){30}}}<br /> {\color{blue}\put(30, 20){\vector(1, 2){10}}}<br /> \thicklines<br /> \put(30, 20){\vector(-4, 1){30}}<br /> \put(30, 20){\vector(-1, 4){5}}<br /> \thinlines<br /> \put(30, 20){\vector(-1, -1){5}}<br /> \put(30, 20){\vector(-1, -4){5}}<br /> \end{picture}[/tex]
  • #695
Does anyone know of any good tutorials for drawing vectors in latex?
  • #696
As you probably have realized by now, LaTeX's \vector and \line in the picture environment have a limited number of available slopes.
http://www.eng.cam.ac.uk/help/tpl/textprocessing/teTeX/latex/latex2e-html/ltx-43.html
http://www.ursoswald.ch/LaTeXGraphics/picture/picture.html [nice examples]
jpicedt for LaTeX, a drawing application in java, makes clever use of \multiput to emulate lines and vectors of any slope. Unfortunately, the resulting \multiput commands are [for me] not intuitively easy to modify. However, you can use jpicedt in eepic mode, which expresses a line in terms of endpoints, rather than "[some measure of] magnitude" and direction. Then, you have to edit those lines to use the \qbezier statement (since eepic is not available on PF).
simple examples:
https://www.physicsforums.com/showpost.php?p=996129&postcount=720
https://www.physicsforums.com/showpost.php?p=969925&postcount=695
fancy examples:
https://www.physicsforums.com/showpost.php?p=968227&postcount=689 [my first example with \qbezier]
https://www.physicsforums.com/showpost.php?p=968788&postcount=692
By the way, i would be nice if something like jpicedt (possibly modified for use at PF) were available here. A picture is worth a thousand words. [It need not be LaTeX-related... it could be another web-standard like SVG.]
  • #697
Thanks Rob, I'll have a bash at that tonight. Btw, is there anyway to label the vector?
  • #698
[tex] \dot{h} \hspace{.5 in} \dot{\theta}[/tex]
[tex] \large<br /> \dot{h} \hspace{.5 in} \dot{\theta}[/tex]
[tex] \mathbf<br /> \dot{h} \hspace{.5 in} \dot{\theta}[/tex]
[tex] \mathtt<br /> \dot{h} \hspace{.5 in} \dot{\theta}[/tex]
[tex] \huge<br /> \dot{h} \hspace{.5 in} \dot{\theta}[/tex]
[tex] \.{h} \hspace{.5 in} \.{\theta}[/tex]
Is there anyway to make over-dots with the dot being more visible than a flyspeck?
  • #699
[tex]\stackrel{\centerdot}{\theta}\dot\theta[/tex]
[tex]\def\DOT#1{\stackrel{\centerdot}{#1}}<br /> \DOT{\theta}[/tex]
[tex]\def\DOT#1{\stackrel{\mathbf\centerdot}{#1}}<br /> \DOT{\theta}[/tex]
[tex]\def\DOT#1{\stackrel{\tiny\bullet}{#1}}<br /> \DOT{\theta}[/tex]
  • #700
[tex] <br /> \]<br /> \begin{picture}(375,225)(0,0)<br /> <br /> \put(100.0,82.0){\rule[-0.200pt]{4.818pt}{0.400pt}}<br /> \put(80,82){\makebox(0,0)[r]{ 0}}<br /> \put(294.0,82.0){\rule[-0.200pt]{4.818pt}{0.400pt}}<br /> \put(100.0,103.0){\rule[-0.200pt]{4.818pt}{0.400pt}}<br /> \put(80,103){\makebox(0,0)[r]{ 1}}<br /> \put(294.0,103.0){\rule[-0.200pt]{4.818pt}{0.400pt}}<br /> \put(100.0,123.0){\rule[-0.200pt]{4.818pt}{0.400pt}}<br /> \put(80,123){\makebox(0,0)[r]{ 2}}<br /> \put(294.0,123.0){\rule[-0.200pt]{4.818pt}{0.400pt}}<br /> \put(100.0,144.0){\rule[-0.200pt]{4.818pt}{0.400pt}}<br /> \put(80,144){\makebox(0,0)[r]{ 3}}<br /> \put(294.0,144.0){\rule[-0.200pt]{4.818pt}{0.400pt}}<br /> \put(100.0,164.0){\rule[-0.200pt]{4.818pt}{0.400pt}}<br /> \put(80,164){\makebox(0,0)[r]{ 4}}<br /> \put(294.0,164.0){\rule[-0.200pt]{4.818pt}{0.400pt}}<br /> \put(100.0,185.0){\rule[-0.200pt]{4.818pt}{0.400pt}}<br /> \put(80,185){\makebox(0,0)[r]{ 5}}<br /> \put(294.0,185.0){\rule[-0.200pt]{4.818pt}{0.400pt}}<br /> \put(100.0,82.0){\rule[-0.200pt]{0.400pt}{4.818pt}}<br /> \put(100,41){\makebox(0,0){ 0}}<br /> \put(100.0,165.0){\rule[-0.200pt]{0.400pt}{4.818pt}}<br /> \put(143.0,82.0){\rule[-0.200pt]{0.400pt}{4.818pt}}<br /> \put(143,41){\makebox(0,0){ 1}}<br /> \put(143.0,165.0){\rule[-0.200pt]{0.400pt}{4.818pt}}<br /> \put(186.0,82.0){\rule[-0.200pt]{0.400pt}{4.818pt}}<br /> \put(186,41){\makebox(0,0){ 2}}<br /> \put(186.0,165.0){\rule[-0.200pt]{0.400pt}{4.818pt}}<br /> \put(228.0,82.0){\rule[-0.200pt]{0.400pt}{4.818pt}}<br /> \put(228,41){\makebox(0,0){ 3}}<br /> \put(228.0,165.0){\rule[-0.200pt]{0.400pt}{4.818pt}}<br /> \put(271.0,82.0){\rule[-0.200pt]{0.400pt}{4.818pt}}<br /> \put(271,41){\makebox(0,0){ 4}}<br /> \put(271.0,165.0){\rule[-0.200pt]{0.400pt}{4.818pt}}<br /> \put(314.0,82.0){\rule[-0.200pt]{0.400pt}{4.818pt}}<br /> \put(314,41){\makebox(0,0){ 5}}<br /> \put(314.0,165.0){\rule[-0.200pt]{0.400pt}{4.818pt}}<br /> \put(100.0,82.0){\rule[-0.200pt]{51.553pt}{0.400pt}}<br /> \put(314.0,82.0){\rule[-0.200pt]{0.400pt}{24.813pt}}<br /> \put(100.0,185.0){\rule[-0.200pt]{51.553pt}{0.400pt}}<br /> \put(100.0,82.0){\rule[-0.200pt]{0.400pt}{24.813pt}}<br /> \put(-566,145){\makebox(0,0)[r]{sqrt(x*x-1)}}<br /> \put(-546.0,145.0){\rule[-0.200pt]{24.090pt}{0.400pt}}<br /> \put(145,88){\usebox{\plotpoint}}<br /> \multiput(145.59,88.00)(0.488,0.560){13}{\rule{0.117pt}{0.550pt}}<br /> \multiput(144.17,88.00)(8.000,7.858){2}{\rule{0.400pt}{0.275pt}}<br /> \multiput(153.00,97.59)(0.645,0.485){11}{\rule{0.614pt}{0.117pt}}<br /> \multiput(153.00,96.17)(7.725,7.000){2}{\rule{0.307pt}{0.400pt}}<br /> \multiput(162.00,104.59)(0.933,0.477){7}{\rule{0.820pt}{0.115pt}}<br /> \multiput(162.00,103.17)(7.298,5.000){2}{\rule{0.410pt}{0.400pt}}<br /> \multiput(171.00,109.59)(0.762,0.482){9}{\rule{0.700pt}{0.116pt}}<br /> \multiput(171.00,108.17)(7.547,6.000){2}{\rule{0.350pt}{0.400pt}}<br /> \multiput(180.00,115.59)(0.933,0.477){7}{\rule{0.820pt}{0.115pt}}<br /> \multiput(180.00,114.17)(7.298,5.000){2}{\rule{0.410pt}{0.400pt}}<br /> \multiput(189.00,120.60)(1.212,0.468){5}{\rule{1.000pt}{0.113pt}}<br /> \multiput(189.00,119.17)(6.924,4.000){2}{\rule{0.500pt}{0.400pt}}<br /> \multiput(198.00,124.59)(0.933,0.477){7}{\rule{0.820pt}{0.115pt}}<br /> \multiput(198.00,123.17)(7.298,5.000){2}{\rule{0.410pt}{0.400pt}}<br /> \multiput(207.00,129.59)(0.933,0.477){7}{\rule{0.820pt}{0.115pt}}<br /> \multiput(207.00,128.17)(7.298,5.000){2}{\rule{0.410pt}{0.400pt}}<br /> \multiput(216.00,134.60)(1.212,0.468){5}{\rule{1.000pt}{0.113pt}}<br /> \multiput(216.00,133.17)(6.924,4.000){2}{\rule{0.500pt}{0.400pt}}<br /> \multiput(225.00,138.59)(0.933,0.477){7}{\rule{0.820pt}{0.115pt}}<br /> \multiput(225.00,137.17)(7.298,5.000){2}{\rule{0.410pt}{0.400pt}}<br /> \multiput(234.00,143.59)(0.933,0.477){7}{\rule{0.820pt}{0.115pt}}<br /> \multiput(234.00,142.17)(7.298,5.000){2}{\rule{0.410pt}{0.400pt}}<br /> \multiput(243.00,148.60)(1.212,0.468){5}{\rule{1.000pt}{0.113pt}}<br /> \multiput(243.00,147.17)(6.924,4.000){2}{\rule{0.500pt}{0.400pt}}<br /> \multiput(252.00,152.60)(1.066,0.468){5}{\rule{0.900pt}{0.113pt}}<br /> \multiput(252.00,151.17)(6.132,4.000){2}{\rule{0.450pt}{0.400pt}}<br /> \multiput(260.00,156.59)(0.933,0.477){7}{\rule{0.820pt}{0.115pt}}<br /> \multiput(260.00,155.17)(7.298,5.000){2}{\rule{0.410pt}{0.400pt}}<br /> \multiput(269.00,161.60)(1.212,0.468){5}{\rule{1.000pt}{0.113pt}}<br /> \multiput(269.00,160.17)(6.924,4.000){2}{\rule{0.500pt}{0.400pt}}<br /> \multiput(278.00,165.59)(0.933,0.477){7}{\rule{0.820pt}{0.115pt}}<br /> \multiput(278.00,164.17)(7.298,5.000){2}{\rule{0.410pt}{0.400pt}}<br /> \multiput(287.00,170.60)(1.212,0.468){5}{\rule{1.000pt}{0.113pt}}<br /> \multiput(287.00,169.17)(6.924,4.000){2}{\rule{0.500pt}{0.400pt}}<br /> \multiput(296.00,174.59)(0.933,0.477){7}{\rule{0.820pt}{0.115pt}}<br /> \multiput(296.00,173.17)(7.298,5.000){2}{\rule{0.410pt}{0.400pt}}<br /> \multiput(305.00,179.60)(1.212,0.468){5}{\rule{1.000pt}{0.113pt}}<br /> \multiput(305.00,178.17)(6.924,4.000){2}{\rule{0.500pt}{0.400pt}}<br /> \put(-206,145){\makebox(0,0)[r]{.866*x}}<br /> <br /> \<br /> \end{picture}<br /> \[[/tex]
  • #701
[tex] \]<br /> \\begin{picture}(750,450)(0,0)<br /> \footnotesize<br /> \qb(205,166)(246,166)<br /> \qb(626,166)(585,166)<br /> \put(164,166){\makebox(0,0)[r]{ 0}}<br /> \qb(205,206)(246,206)<br /> \qb(626,206)(585,206)<br /> \put(164,206){\makebox(0,0)[r]{ 1}}<br /> \qb(205,247)(246,247)<br /> \qb(626,247)(585,247)<br /> \put(164,247){\makebox(0,0)[r]{ 2}}<br /> \qb(205,287)(246,287)<br /> \qb(626,287)(585,287)<br /> \put(164,287){\makebox(0,0)[r]{ 3}}<br /> \qb(205,328)(246,328)<br /> \qb(626,328)(585,328)<br /> \put(164,328){\makebox(0,0)[r]{ 4}}<br /> \qb(205,368)(246,368)<br /> \qb(626,368)(585,368)<br /> \put(164,368){\makebox(0,0)[r]{ 5}}<br /> \qb(205,166)(205,207)<br /> \qb(205,368)(205,327)<br /> \put(205,83){\makebox(0,0){ 0}}<br /> \qb(289,166)(289,207)<br /> \qb(289,368)(289,327)<br /> \put(289,83){\makebox(0,0){ 1}}<br /> \qb(373,166)(373,207)<br /> \qb(373,368)(373,327)<br /> \put(373,83){\makebox(0,0){ 2}}<br /> \qb(458,166)(458,207)<br /> \qb(458,368)(458,327)<br /> \put(458,83){\makebox(0,0){ 3}}<br /> \qb(542,166)(542,207)<br /> \qb(542,368)(542,327)<br /> \put(542,83){\makebox(0,0){ 4}}<br /> \qb(626,166)(626,207)<br /> \qb(626,368)(626,327)<br /> \put(626,83){\makebox(0,0){ 5}}<br /> \qb(205,166)(626,166)(626,368)(205,368)(205,166)<br /> \put(-1178,286){\makebox(0,0)[r]{sqrt(x*x-1)}}<br /> \thinlines \path(4294966159,286)(4294966364,286)<br /> \thinlines \path(293,178)(293,178)(310,196)(328,209)(345,220)(363,230)(380,240)(398,249)(416,259)(433,268)(451,277)(468,286)(486,294)(503,303)(521,312)(538,321)(556,329)(573,338)(591,347)(608,355)(626,364)<br /> \put(-440,286){\makebox(0,0)[r]{.866*x}}<br /> \qb(4294966897,286)(4294967102,286)<br /> \qb(205,166)(205,166)(223,173)(240,181)(258,188)(275,195)(293,202)(310,210)(328,217)(345,224)(363,232)(380,239)(398,246)(416,253)(433,261)(451,268)(468,275)(486,283)(503,290)(521,297)(538,304)(556,312)(573,319)(591,326)(608,334)(626,341)<br /> \put(298,286){\makebox(0,0)[r]{.866}}<br /> \qb(339,286)(544,286)<br /> \qb(205,201)(205,201)(223,201)(240,201)(258,201)(275,201)(293,201)(310,201)(328,201)(345,201)(363,201)(380,201)(398,201)(416,201)(433,201)(451,201)(468,201)(486,201)(503,201)(521,201)(538,201)(556,201)(573,201)(591,201)(608,201)(626,201)<br /> \qb(205,166)(626,166)(626,368)(205,368)(205,166)<br /> \end{picture}<br /> <br /> \[[/tex]
  • #702
Could someone please help me draw a digraph of 5 nodes with weights and loops included ? I just couldn't find out any articles out there in ctan that could help me accomplish this.
  • #703
latex help
friends, i have an equation which is to be typeset in latex. will anyone of you be kind enough to let me know how to do it in latex.
the equation is x=A.y where x and y are 3x1 vectors each (i.e. a column vector with 3 rows), A is a 3x3 square matrix (i.e., 3 rows and 3 columns). Can anyone help me
  • #704
A quick google search on typesetting matrices in latex will show you how to do it for any matrices. Go on, give it a go.
  • #705
GSampson said:
Let me try
[tex]\alpha^\gamma[\tex][/tex]
[tex] <br /> Change your last tag to (without the spaces);<br /> <br /> [ /tex ][/tex]
  • #706
[tex]\stackrel{\to}{\to}[/tex]
[tex]\leftleftarrows[/tex]
  • #707
How do I get daggers for foonotes?
I have no idea how to make the dagger appear for the footnote..I've been looking online and all I come across are sites that say nothing how to do this. Any help would be appreciated.
  • #708
footnote[itex]^\dagger[/itex]
[itex]^\dagger[/itex]Do you mean like this?
  • #709
figured it out...
I guess that's one way to do it...but I would rather not cheat and just let Latex automatically format my text...instead what I did was download the footmisc package and then use the 'symbol*' argument and when i typed \footnote...i had to do \footnote[2] since 1 = * and 2 = \dagger...
  • #710
test:
[tex](-\frac{1}{2}\ln{\sin{x}}+C)[/tex]
[tex]x^2\sqrt{x}[/tex]
NOTE:
the crash course has a major typo (if I'm not mistaken)
look at the 2 things I've encircled
  • #711
Does anyone know the fancy cursive way to denote a powerset.
I'm not talking about [tex]\mathcal{P} = \{A_j : j \in J \}[/tex]
  • #712
There is [tex]\mathfrak{P}[/tex]. if that is not it i think you will need another font package like fourier, and i do not think the forum supports those (does it?)
See page 6 in http://www.tex.ac.uk/tex-archive/fonts/fourier-GUT/doc/latex/fourier/fourier-doc-en.pdf to see how the fouier--calligraphic P looks like
  • #713
i have a question regarding tex, before tex was invented, how did scientists published equations through the internet?
  • #714
I am under the impression that typesetting software, like troff, predated both TeX and the internet. A quick survey of Google supports this clearly.
TeX was born in 1982, which was in the infancy of "The Internet" http://www.tug.org/ftp/historic/systems/unix/TeX2.9/tex82/TeXdoc/history.txt
For the early days of UNIX: The AT&T Man pages are typeset in nroff for terminals and troff for publishing. An additional utility, eqn, was a nroff preprocessor specific for equations. These have been around since the early 1970s.
http://ezine.daemonnews.org/199903/history.html
Prior to UNIX, in the 1960s, was CTSS which had RUNOFF which was an ancestor of VAX/VMS RUNOFF and UNIX troff, and GNU gtroff
http://mit.edu/Saltzer/www/publications/AH.9.01.html
http://www.multicians.org/thvv/7094.html
Prior to RUNOFF, there may have been a variety of custom (proprietrary) typesetting solutions used by published in the 1960's.
  • #715
For the powerset fancy lettering I used calligra..found on this website
http://www.tug.dk/FontCatalogue/"
as for ultima9999...it might be just me...but did you mean to use 5^{10}
  • #716
Excuse me, I just want to try it a bit.
[tex]t=\frac{t_0}{\sqrt{1-\frac{v^2}{c^2}}}[/tex]
  • #717
can anyone tell me how to use binomial in laTeX bcoz when i use \binom it doesn't comes up with anything except = mn
can anyone explain this to me ??
  • #718
\binom{}{} requires the amsmath package.
  • #719
You mean this:
[tex]\left( \begin{array}{c} n \\ k \end{array} \right)[/tex]?
  • #720
Testing:
[tex] \setlength{\unitlength}{6cm}<br /> \begin{picture}(1, 1)<br /> \put(0, 0){\line(0, 1){1}}<br /> \put(0, 0){\line(1, 0){1}}<br /> \put(0, 0){\line(1, 1){1}}<br /> \put(0, 0){\line(1, 2){.5}}<br /> \put(0, 0){\line(1, 3){.33333}}<br /> \put(0, 0){\line(1, 4){.25}}<br /> \put(0, 0){\line(1, 5){.2}}<br /> \put(0, 0){\line(1, 6){.16667}}<br /> \put(0, 0){\line(2, 1){1}}<br /> \put(0, 0){\line(2, 3){.6667}}<br /> \put(0, 0){\line(2, 5){.4}}<br /> \put(0, 0){\line(3, 1){1}}<br /> \put(0, 0){\line(3, 2){1}}<br /> \put(0, 0){\line(3, 4){.75}}<br /> \put(0, 0){\line(3, 5){.6}}<br /> \put(0, 0){\line(4, 1){1}}<br /> \put(0, 0){\line(4, 3){1}}<br /> \put(0, 0){\line(4, 5){.8}}<br /> \put(0, 0){\line(5, 1){1}}<br /> \put(0, 0){\line(5, 2){1}}<br /> \put(0, 0){\line(5, 3){1}}<br /> \put(0, 0){\line(5, 4){1}}<br /> \put(0, 0){\line(5, 6){.8333}}<br /> \put(0, 0){\line(6, 1){1}}<br /> \put(0, 0){\line(6, 5){1}}<br /> \end{picture}[/tex]
[tex] \definecolor{hellgrau}{gray}{.8}<br /> \definecolor{dunkelblau}{rgb}{0, 0, .7}<br /> \definecolor{roetlich}{rgb}{1, .7, .7}<br /> \definecolor{dunkelmagenta}{rgb}{.3, 0, .3}<br /> <br /> \setlength{\unitlength}{1cm}<br /> \begin{picture}(6, 8)<br /> \linethickness{0.075mm}<br /> \multiput(0, 0)(6, 0){2}{\line(0, 1){8}}<br /> \multiput(0, 0)(0, 8){2}{\line(1, 0){6}}<br /> \thicklines<br /> \color{dunkelmagenta}<br /> \put(1, .5){\line(2, 1){3}}<br /> \put(4, 2){\line(-2, 1){2}}<br /> \put(2, 3){\line(-2, -5){1}}<br /> \put(.7, .3){\makebox(0,0)[cc]{B}} <br /> \put(4.05, 1.9){\makebox(0,0)[cc]{B}}<br /> \put(1.7, 2.95){\makebox(0,0)[cc]{C}}<br /> \put(3.1, 2.5){\makebox(0,0)[cc]{a}}<br /> \put(1.3, 1.7){\makebox(0,0)[cc]{b}}<br /> \put(2.5, 1.05){\makebox(0,0)[cc]{c}}<br /> \color{dunkelblau}<br /> \put(0.3, 4){\makebox(0,0)[cc]{F=\sqrt{s(s-a)(s-b)(s-c)}}}<br /> \end{picture}[/tex]
[tex] \definecolor{cred}{rgb}{1, 0, 0}<br /> \definecolor{cgreen}{rgb}{0, 1, 0}<br /> \definecolor{cblue}{rgb}{0, 0, 1}<br /> \setlength{\unitlength}{1mm}<br /> \begin{picture}{60, 60}<br /> \put(30, 30){\circle{14}}<br /> \put(23, 23){\line(1, 0){14}}<br /> \put(23, 23){\line(0, 1){14}}<br /> \put(37, 37){\line(0, -1){14}}<br /> \put(37, 37){\line(-1, 0){14}}<br /> \color{cred}<br /> \put(30, 23){\line(0, 1){14}}<br /> \put(23, 30){\line(1, 0){14}}<br /> \end{picture}[/tex]
This is driving me crazy... :cry: Does anyone know why there's a text 0, 60 in the third picture? I didn't put any text there, it just appeared mysteriously... :frown:
The circle command is too small, since the diameter can only be 14 mm. I just wonder if there is a way to magnify the picture? Or to draw a larger circle?
