Calculating Forces on a Coasting Car: Newton's Laws and Air Drag Calculation
  • Thread starter Thread starter physicsgal
    Laws Newton's laws
The discussion revolves around calculating forces and displacements related to a car coasting and experiencing air drag, as well as analyzing a tug of war scenario on a frictionless surface. The subject area includes Newton's laws of motion and kinematics.
  • Mixed
  • Participants explore calculations for average acceleration and forces acting on a coasting car, questioning the setup and assumptions involved in the calculations. There are attempts to clarify the methodology for determining forces and displacements in both scenarios presented.
Some participants have provided guidance on how to approach the calculations, while others are verifying their results and seeking confirmation on their reasoning. Multiple interpretations of the problems are being explored, particularly regarding the forces involved in the tug of war scenario.
Participants are working under the constraints of homework rules, which may limit the information they can use or the methods they can apply. There is an ongoing discussion about the accuracy of calculations and the assumptions made in each scenario.
physicsgal
"a person drives their 1452 kg car along a straight road at a constant velocity of 30 m/s east. their brakes suddenly give out. they put the car in neutral and let is coast for 25 seconds. the air drag decelerates the car to a velocity of 25 m/s east. (assume a frictionless surface)."
b) assume the average acceleration while the car is decelerating
so it's just (25 m/s - 30 m/s)/25 s = -0.2 m/s^2?
c) determine the average force of air against the car
f = ma
= (1452 kg)(-0.2)
= 290.4 N
d) after coasting for 25s. they pull their car handbrake to slow the car to a stop. this take 3 seconds. what is the force applied by the handbrake? assume that the force exerted by the air remains constant and is equal to the forced determined in part (c).
so i assume i find acceleration by (0 - 25)/time
but for the time is it (25s-3s) or (3s - 25s)?
and then i just the acceleration times the mass of car = handbrake force?
any help will be appreciated!
~Amy
You have to consider only the last 3 seconds during which the car is moving.
That's right.
thanks neutrino.
for d) i got -8.33 m/s^2 for the acceleration abd -12100N for the force of the handbrake.
in e) it asks "what is the total displacement from the time the brakes give out to the time the car stops"
so for this i used the formula:
d = (0.5)at^2 + v1t
= (o.5)(-8.33)(3^2) + (25m/s)(25s)
= 587.52m
can someone tell me if this is accurate?
~Amy
another question i want to check:
"peter and john are playing tug of war on a frictionless surface. peter weighs 539N and john weights 393N. john accelerates towards peter at 3 m/s^2. "
a) what is the magnitude of the force that peter exerts on john?
539N times 3 m/s^2
= 1617N?
any help is appreciated!
~Amy
for this one:
first i calculated john and peters mass by diving this Newton weight by the force of gravity (9.8 m/s^2). so peter is 55 kg, and john is 40 kg.
then for part a) i took peters mass (55 kg) times (-3 m/s^2)
= -165N.
not sure if this is accurate. help?
~Amy
No. Don't forget that the air is still exerting its force.
No, you found the net force.
d = (0.5)at^2 + v1t
= 587.52m
Divide the motion into two segments and find the displacement in each:
(1) air drag only (coasting)
(2) air drag + hand brake
physicsgal said:
for this one:
OK.
= -165N.
No. To find the force on John, multiply John's mass times John's acceleration.
so i'd be -121000N - -290.4N?
will do (and will post my results later)
:blushing: thanks!
so it'd be 120N
what then how would i find the magnitude of the force that john exerts on peter? would it be -120N?
thank you
~Amy
Yes.
so it'd be 120N
Right.
Yes. Newton's 3rd law should tell you that they exert equal and opposite force on each other. (But realize that magnitudes are always positive. :wink: )
ok. for (1) i got (0.5)(30m/s + 25 m/s)(25s)
= 687.5 m
for (2) i got (0.5)(-8.33 m/s^2)(3^2)
= -37.485
so 687.5 + - 37.485
= 650.02 m
:biggrin:
more on the john/peter saga..
"sarah decides to join the game as well. now peter pulls on sarah with a force of 45 N east, and john pulls on her with a force of 25N north. what is sarah's resultant acceleration, if she weighs 294N?"
so first of all she weighs 30kg
and to find the c^2 it's (45^2) + (25^2)
= 51.48 N
and to find the tan angle is 26 degree north/west.
so to find sarah's acceleration i go 51.48N/30 kg?
~Amy
= 687.5 m
Good.
= -37.485
Nope. Sanity check: It slows down, but doesn't go backwards. :eek:
Use the full equation:
[tex]d = v_0 t + (1/2) a t^2[/tex]
(don't forget the initial velocity!)
You can also use the exact same equation you used for segment (1). :wink:
= 51.48 N
Good.
Check this one. Her acceleration should be north-east.
Good.
= -37.485
(i knew the negative displacement sounded a bit suspicious, lol)
ok so (25m/s)(3s) + (0.5)(-8.333)(3^2)
= 37.515
650.02+37.515
= 687.54 m :biggrin:
thanks for the help!
~Amy
= 37.515
Good. But you can also use the same equation that you used for segment (1): d = (0.5)(25 m/s + 0 m/s)(3 s)
650.02+37.515
= 687.54 m
I think you copied the answer from (1) wrong.
My pleasure.
= 687.54 m
thanks. i just noticed that too. so the total displacement should be 725.02 m east :smile:
~Amy
  • · Replies 17 ·
  • · Replies 20 ·
