Small-Scale Glider Flight: Physics and Aerodynamics Explained
The discussion centers around the physics and aerodynamics of small-scale glider models compared to full-sized gliders. Participants explore the reasons why smaller models may not perform as well in flight, touching on concepts such as airflow, viscosity, and Reynolds number.
  • One participant questions why an exact model of a glider does not fly as well as a full-sized version, suggesting that air does not flow around a small wing as effectively.
  • Another participant speculates that the reduced number of air molecules in a scaled volume affects the continuum approximation, potentially amplifying random effects in airflow.
  • A different viewpoint emphasizes that viscosity becomes more significant in smaller models, leading to relatively more turbulent flow and altered aerodynamic properties.
  • Participants mention the importance of Reynolds number as a rule of thumb for determining flow similarity between different sizes and speeds.
  • One participant notes that smaller models experience reduced lift due to the effects of wingtip vortices, which are more pronounced relative to the smaller surface area.
  • There is a discussion about the scaling of mass and area, with one participant explaining that mass scales with the cube of dimensions while area scales with the square, impacting lift generation.
  • Another participant highlights that smaller models typically fly slower, which contributes to generating less lift per unit area of wing.
Participants express various viewpoints on the factors affecting the performance of small-scale glider models, with no consensus reached on the primary reasons or the implications of scaling effects.
Participants mention the limitations of applying Reynolds number theory to scaled models, indicating that scale effects may lead to inaccuracies in predictions of aerodynamic behavior.
cucumber
hello.
the question is: if i have an exact model (and i mean EXACT) of, say, a glider (you know, those whaddamacallits, white things, long, thin wings, those ones), if i have one of those, why will it not fly as well as a proper one?
(the model is a lot smaller than the real thing)
i was told that the air does not flow around a small wing as well as it does around a large one.
is that true?
if so, why so?
thanks.
I would imagine it has something to do with there being less actual air molecules in a given scaled volume for the model, so the continuum approximation doesn't work as well. Total conjecture, though.
To elaborate on my lines of thinking with an example: Random collisions with individual air molecules will not be as evened out, because there will actually be less (statistically) in any given time. This may amplify random effects.
Individual molecules are not the problem. The issue has to do with viscosity. The smaller the model, the more the air appears viscous. As a result, the flow is relatively more turbulent, which affects the aerodynamic properties.
Look up something called the Reynold's number. Its gives a good rule of thumb for determining when fluid flows are similar.
With a smaller model you also get reduced lift. Along the tips of the wings, the higher pressure on the bottom of the wing 'bleeds' over to the top of the wing. With a smaller model, there is less surface area to tip area, so the wingtip vorteces have a greater effect.
Why is that?
Enigma and I are very insulted that you posted this in the General Physics forum instead of the Aerospace Engineering forum.
Wha? Er. Oh yeah! VERY insulted...
You know... You'r right, this is an engineering discussion!
Enjoy!
Look up "Scaling Theory" for more info. It's been many years since I studied aero-d, so I forget the details at the moment. [b(] I would need to dust off my old college textbooks. But it sounds like mathman, stingray, and enigma are on the right track. Smaller-scale models are frequently used (wind tunnels, etc.) and there is always some loss of accuracy compared to a full-scale application.
The answer to this lies with the concept of Reynolds number.
Basically due to density and viscosity airflow forms different flows at different speeds and body sizes. Assuming that the density and viscosity are the same, you get the same flow if you double the speed and halve the body size etc. When you scale down a model, you are generally scaling down both the velocity and the size of the body
vastly reducing the reynolds number. The aristream has far less energy to keep laminar flow going long. The curvature of the body is smaller and is much more difficult for the boundary layer to stay attached to the surface. The boundary layer turbulates earlier and is of an much more significant proportion of the body. Any resulting separation bubbles that would be insignificant on a full size aircraft can extent over a major proportion of the model wing and may in fact not reattach at all.
Reynolds number theory does not hold as good at the vaules related to models because of these scale effects.
is the scaled model with mass that scaled in the same propotion as the size??
One thing to remember here is that mass is proportional to the cube of any dimension (and area is the square of any dimension). So if you say a plane with half the wingspan of another is half the size - its actually going to have a quarter the wing area and an eighth the volume. Even still, an rc plane is significantly lighter: I googled for a http://www.enter.net/~kellys00/info.html has a wing loading of about 1.5 lb/sq ft.
One thing to remember is that besides being smaller, the model also flies much slower, generating much less lift per unit area of wing than the real thing. Slower + smaller = that Reynold's number thing discussed above.
  • · Replies 28 ·
  • · Replies 24 ·
16K
