What is the relation between refractive index and wavelength in a prism?
The discussion revolves around the relationship between the refractive index of a prism's material and the wavelength of light passing through it. Participants explore the implications of this relationship, particularly in the context of practical experiments and the physical significance of the refractive index's dependence on wavelength.
  • Experimental/applied
  • Some participants assert that the refractive index decreases with increasing wavelength, emphasizing the physical significance of this relationship rather than seeking a formula.
  • Others suggest that practical experimentation is necessary to measure the refractive index for different wavelengths, highlighting the dependence on the composition of the glass.
  • One participant notes that normal dispersion occurs when the refractive index decreases with increasing wavelength, but mentions the existence of anomalous dispersion where the refractive index increases at certain wavelengths.
  • A later reply elaborates on the microscale interactions between electromagnetic waves and atomic charges, explaining how these interactions affect the speed of light in a medium.
  • Several participants share resources, including websites that provide dispersion curves for various materials, indicating a collaborative effort to find additional information.
Participants generally agree that the refractive index decreases with increasing wavelength under normal dispersion conditions. However, there is acknowledgment of the complexity introduced by anomalous dispersion, and the discussion remains unresolved regarding the specifics of these phenomena and their implications.
Some limitations include the dependence on the exact composition of the glass and the potential for resonance effects that complicate the relationship between refractive index and wavelength.
Christa
This is from my Physics practical experiments.
The experiment is to find the refractive power of the prism for different colours and also to determine the dispersive power of the material of the prism.
My question is how does the refractive index of the material of the prism vary with the wavelength of the source light used?
The answer is the refractive index decreases with the increase in the wavelength of the light.
I do not want the equation of the relation but the physical significance of the relation.
Science news on Phys.org
If this is for "practical experiments", then DO IT and find out! Measure the angle of refraction of several different kinds of transparent materials and wavelengths. For a "practical experiment" you shouldn't be trying to find a formula before doing the experiment.
You are unlikely to find such an equation anyway because it is dependent on the composition of the glass. So unless you know the composition of the glass exactly (which I very much doubt), the only way to obtain this information is to measure it directly anyway.
Claude.
This is a pretty open ended question - I would start with the fact that different wavelengths will travel through the glass at different speeds, which results in material dispersion - different wavelengths separate in time and space when propagating through the glass.
Claude.
You can find dispersion curves (refractive index as a function of wavelength) for many materials on http://refractiveindex.info/"
The refractive index is related to the velocity of light in the medium.
The velocity of light in the medium is related to the interactions of the incoming electric
field of the radiation ,with the electric fields in the medium.
The higher the frequency of the radiation , the more radiation/medium electric field interactions, which reduces velocity and equals a higher refractive index.
Is that your website? It's great! Very useful :-)
Thanks!
You can check also an advanced version of the site: http://dispersion.info/"
Christa said:
<snip>
That is true for normal dispersion: the refractive index decreases as the wavelength increases. Until an resonance peak, that is- then there is anomalous dispersion, where the refractive index *increases* with increasing wavelength. Anomolous dispersion is responsible for those "light moving faster than 'c'" experiments.
The phenomenon of resonance is the origin of normal dispersion.
The following is a more complete explanation:
At the microscale an electromagnetic wave is slowed in a material because the electric field
creates a disturbance in the charges of each atom- primarily the electron proportional to the permittivity.
The oscillation of charges itself causes the radiation of an electromagnetic wave that is slightly out of phase with the original. The sum of the two waves creates a wave of the same frequency but shorter wavelength than the original leading to slowing of the waves travel. (1)
An electron in an atom or molecule is bound there by strong restoring forces. It has a definite natural frequency. For electrons in atoms it is usually in a region corresponding to violet or U.V. light.
In mechanical systems it is possible to "drive" the system most effectively if we impress on it an external force whose frequency is as close as possible to that of the natural resonant frequency.
In the case of light the blue is closer to the natural resonant frequency of the bound electrons than red light. Therefore we would expect the blue light to be more effective in causing the electrons to oscillate. (2)
ref. :
1) http://explanation-guide.info
2)Physics Halliday-Resnick p 1077
Another link to a good site I've never seen before. This thread is a gold mine for good sites.
  • · Replies 207 ·
16K
