The sun's gravitational pull on the earth
The discussion centers around the hypothetical scenario of the sun vanishing and its implications for the Earth, particularly focusing on gravitational effects, tidal forces, and the nature of orbital motion. Participants explore concepts from general relativity and the speed of gravity, as well as the potential consequences of such an event on Earth's structure and motion.
  • Some participants propose that if the sun were to vanish, the Earth would continue to orbit as if the sun were still present for about 8 minutes due to the time it takes for light and gravitational effects to reach the Earth.
  • Others argue that gravity travels at the speed of light, meaning any change in the sun's gravitational field would also take 8 minutes to be felt on Earth.
  • A participant mentions that without the sun's gravitational pull, tidal forces would cease, potentially leading to significant geological consequences.
  • Some express uncertainty about the nature of tidal forces and whether the Earth's crust would experience immediate or gradual changes after the sun's disappearance.
  • There is a discussion about whether observers equidistant from the Earth and sun would perceive the sun's disappearance and the Earth's trajectory change simultaneously.
  • One participant suggests that the sudden absence of the sun would not cause catastrophic geological changes, citing the relatively small amplitude of the sun's tidal forces compared to oceanic tides.
  • Another participant notes that while the immediate effects might not be catastrophic, the absence of sunlight would be perceptible to those on the near side of the Earth.
Participants express a range of views on the implications of the sun's disappearance, with no clear consensus on the geological effects or the nature of tidal forces. The discussion remains unresolved regarding the specifics of how the Earth's crust would react and the timing of observable changes.
Some claims depend on assumptions about gravitational propagation and the nature of tidal forces, which are not fully resolved in the discussion. The implications of general relativity and the speed of gravity are also explored but remain contested.
Mono182
if the sun was to vanish, what would happen to the earth. I've been told that the Earth would still rotate around as if there was a sun, was atleast 8 minutes because that's the time it take for the sun's light to reach the earth. Since nothing is faster than the speed of light, the Earth will stay in orbit. is that statement true or is there a better way of explaining it?
Astronomy news on Phys.org
I think that might be true, of course there would be no way to tell that the sun had vanished before those 8 minutes were up, and besides, stars don't just vanish like that.
True, it's an impossible situation. Gravity does travel at the speed of light, though, so any disturbance in the sun's field would take 8 minutes to be noticed here.
so gravity does have a speed?
In Genreal Realtivity the speed of light is also the speed of gravity
Which is exactly what became several L-O-N-G threads on the General Astronomy forum. Check over there for about all the opinions and questions you would ever want to read...:smile:
Thanks. I knew there was at least one around somewhere, but I couldn't remember where.
Danger said:
Full flaps, dammit! That's a tennis court!
Try putting an F-18 down on a rolling Carrier...:biggrin:
No thanks; I get seasick. :biggrin:
May I add that the Earth would be squished by the tidal forces at around the 8 minute mark.
You lost me on that one. If there is no gravitational source, there are no tidal forces.
By the bye, it's nice to see someone finally spell our country properly. :biggrin:
Not squished necessarily, but total disaster. As of now, the Earth is "compressed" by tidal forces between Sun and Moon in a vectored direction.
If the Sun's gravity were to "let go" 499 seconds (mean) after the Sun disappeared, the tidal forces would be instantly gone and the Earth's crust, et. al. would "spring out" and tear the hell out of about everything..
Hmmm... I don't even know whether that would fall under astronomy or planetology or what, but it completely escaped my home-made education. I would have expected the opposite effect, as in the compressive force of gravity no longer being counteracted by tidal force, but with the rotation still keeping the planet 'expanded'. At most, I figured that there would be a slight inward settling of the crust (still devestating to civilization, of course).
Thanks for the tune-in.
That's about all I really meant.
But would this cause the Earth's crust to move any more than it does on a daily basis? Tidal forces compress and extend the crust once for each planetary revoltion, don't they?
Yes, but slowly, not instantly..:eek:
so think of [itex]c[/itex] as not simply the "speed of light" or the "speed of electromagnetic propagation" (which is where it came from originally), but as the speed of propagation of all things "instantaneous".
whether you and your signalling partner are each holding an electric charge (and you're wiggling them back and forth to signal the other) or you and your signalling partner are holding planets and wiggling them around to send "gravity signals", any instantaneous action from whatever source moves at a speed of [itex]c[/itex].
would we even feel the "release" i mean as it is we are falling anyway. If there is no gravity we just feel like we are falling. So if we get released i don't think the Earth would react in any significant and disasterous way.
Correct. It is a little bit of a tricky thing: when you are in orbit, you are falling towards the object you are orbiting and feel nothing. If the object blinks out of existence, you no longer orbit and you feel no forces pulling you toward something that doesn't exist. So you'd notice no change in the forces on you.
Oh yeah, hadn't thought of that.
But then again, from what I've heard the Earth is still bouncing back from deformations caused by the last Ice Age, so the subsidence of the tidal bulge might be a very gradual thing, taking thousands of years.
Pretty sure the sudden absence of the Sun would NOT cause catastrophic rebound from the disappearance of the tidal forces. Quoth http://en.wikipedia.org/wiki/Tidal_acceleration" :
Earth's net equilibrium tide has an amplitude of only 3.23 cm, which is totally swamped by oceanic tides that can exceed one metre.
...for the moon. If you do the math, the Sun's tidal forces are about half as strong. So basically, the sudden disappearance of the Sun would result in an elevation drop of no more than 1.6cm, which would also not be instantaneous due to the Earth's elasticity. In addition, the difference between local elevation changes would be tiny (Probably on the order of nanometers for two sides of an Earthquake fault).
hmm, since gravity travels at the speed of light, if the sun disappeared the Earth would still orbit as if the sun was still there for atleast 8 mins, then we would feel the effects?
Correct, but relax: it can't happen.
but, even so, since orbiting or free-falling toward a graviational source is just an inertial movement from the perspective of GR, we wouldn't even feel the effects after those 8 minutes. the folks on the near side of the Earth would miss the sunlight, but the folks on the far side wouldn't know any difference (except from communications) until the sun fails to rise when it's expected to.
what would be perceptually immediately remarkable is an observer near the axis of the Earth's revolution around the sun, equidistant from the Earth and sun, and far enough away to see the circular or elliptical path of the Earth around the sun would see the Earth continue in its elliptical orbit for 8 minutes after the sun was observed to disappear. that is a different observation than if the speed of gravity was infinite and the Earth was observed to be moving in a straight line immediately after the sun disappears. that's the salient kernel of this thought experiment.
No, I think an observer equidistant between the Earth and Sun would "see" the Sun's dissaperance and the Earth's change of course simultaneously, wouldn't they?
something amusing:
i asked this same question to a group of my friends a while back (then came here for answers) and today it randomly appeared on one of my friend's Earth and space science test. After he read it he was like crap, i should of listened!
The speed of gravity is talked about at great length in
http://math.ucr.edu/home/baez/physics/Relativity/GR/grav_speed.html
If you look for this link in the physics forums, you'll find where this issue has been discussed in the past.
The correct answer to "what happens if the sun dissappears" according to General relativity is "the sun can't disappear". This sitaution is quite analogous to the question of "what happens according to Maxwell's equations if a charge disappears". The conservation of charge is _built into_ Maxwell's equations, and they do not have a sensible solution where charge disappears. Similarly, the conservation of energy and momentum is _built into_ the theory of General Relativity (in the form of certain differential conservation laws - while these laws don't generalize to the usual intergal form that's another topic.). These differential conservation laws would be violated if the sun suddenly disappeared, so General Relativity does not make any prediction as to what would happen in that event. Instead, it says that that event cannot happen.
If you want to measure the speed of gravity, you need to set up a thought experiment that can actually be performed. The answer in theory is fairly simple and similar to the way we measure the speed of light. You acclerate a mass, to measure a gravitational wave (just as accelerating a charge generates an electromagnetic wave) - then you measure the propagation speed of the wave, i.e. how long it takes to arrive. Unfortunately, gravitational radiation is so weak that we currently cannot detect natural events expected to cause it, nor can we generate enough of it to be detectable. We have indirect observations of binary inspiralling stars that convinces us that energy is being carried away by graviational radiation but we cannot measure the radiation directly currently. This may change with Ligo and Lisa, two projects dedicated to detecting natural sources of gravitational radiation (like binary inspirals that generate black holes).
You do _not_ measure the speed of light by making a charge disappear, because this cannot be done. Mathematically, attempting to do this gives nonsense results. Similarly, you do _not_ measure the speed of gravity by making mass disappear, because this cannot be done. You use the mass to generate gravitational waves (or the charge to generate electromagnetic waves) and you measure the speeds of the wave.
why? the Earth (or half of it) would remain illuminated for 8 minutes after the disappearance of the Sun for such an observer. even though it does not change the argument, i was not implying that the observer was between the Earth and Sun in the orbital plane, but far off in space, reasonably close to the axis of revolution of the Earth's orbit (the line going through the sun that is perpendicular to the orbital plane of the Earth) and equidistant from the Earth and Sun. connecting the three, it would be an isosoles triangle with a very acute angle at the observer.
I don't know if I agree with this. I can think of some really ridiculous ways for the sun to disappear that are HORRIBLY unlikely but not ruled out by relativity. For instance, what if the mouth of a wormhole suddenly opened up and sucked the Sun to the different part of the universe, and then the wormhole instantly evaporated? What if we measure the Sun where it is today, and then, by the uncertainty principle, the next time we measure it it has moved 10 light years away (the odds are incredibly tiny, but still, non-zero). I don't think that GR specifically prohibits these scenarios...and I'm sure there are others that would facilitate the Sun's sudden disappearance.
  • · Replies 28 ·
12K
