Calculating Frictional Force and Time to Move a Box Across a Floor
  • Thread starter Thread starter Fanjoni
    Box Weighing
The discussion revolves around calculating the time it takes to move a box of books weighing 229 N across a floor, given a pushing force of 455 N at an angle of 35° below the horizontal. The problem involves two scenarios with different coefficients of kinetic friction (µk) of 0.57 and 0.75.
  • Mixed
  • Participants explore vector components of the applied force and the normal force, questioning how to correctly calculate the frictional force. There is discussion about the reasonableness of calculated acceleration values and the implications of those values on the time to move the box.
Some participants have provided calculations for acceleration and time, while others express skepticism about the reasonableness of the results. There is an ongoing examination of the forces involved and how they relate to the box's movement, with various interpretations being explored.
Participants note the importance of free body diagrams and the need to consider both the weight of the box and the vertical component of the applied force in determining the normal force. There is also a recognition of the potential impact of friction on the overall motion of the box.
Fanjoni
A box of books weighing 229 N is shoved across the floor by a force of 455 N exerted downward at an angle of 35° below the horizontal.
(a) If µk between the box and the floor is 0.57, how long does it take to move the box 5 m, starting from rest?
(b) If µk between the box and the floor is 0.75, how long does it take to move the box 5 m, starting from rest?
I started by finding the x and y vectors x=272.71 y=260.98 Then i tried to th Neutral force and used it in the equation Fk=µk*N But i am lost and don't know hwat to do please help me
Thanks
Thanks
Draw a free body diagram. Remember that N is not simply mg, but also the magnitude of the y-component of the acting force.
[tex]F_{k}=\mu_{k}N[/tex]
[tex]|N|=mg+F_{push}\sin(\theta)[/tex]
You know mg (229 N), [itex]F_{push}[/itex] (455 N), and [itex]\theta[/itex] (35[itex]^{\circ}[/itex] SE).
i found acceleration 15.74 and then found time to be 1.694s is this correct?
I haven't solved the problem, so I don't know if that answer is correct. However, you should ask yourself, does an acceleration of almost 16 [itex]m/s^{2}[/itex] seem reasonable? That's over 30 mph/s, and the box is moving 5 meters in under 2 seconds. I'd say it's probably not correct.
Show your work, and we can pick out the error.
geoffjb said:
I haven't solved the problem, so I don't know if that answer is correct. However, you should ask yourself, does an acceleration of almost 16 [itex]m/s^{2}[/itex] seem reasonable? That's over 30 mph, and the box is moving 5 meters in under 2 seconds. I'd say it's probably not correct.
Actually, it sounds reasonable. Look at the forces involved on a not so massive item.
EDIT: cos(35) * 455N * 9.8m/s^2 / 229N = 15.95
You're saying it's reasonable for a force of 445 N (roughly equal in magnitude to the weight of a pre-teen girl)[itex]-[/itex]and not the full force, but a component of it[itex]-[/itex]to accelerate a 50 pound object to 60 mph in 2 seconds?
Yes.
If it were the full force, 455N, it would accelerate the 23.4kg object at 19.5 m/s^2.
Think about it. The acceleration due to gravity is 9.8m/s^2, correct? That's nearly 22 mph per second. Now, a 229N object in would experience 229N force from gravity, by definition. Soooo, a greater force (hence, a greater than half portion of 455N), would exert a greater acceleration. That's the intuition part that you're arguing with me about. The math works out perfectly as well ;)EDIT: That acceleration is without any friction as well. Which is what I believe he was originally aiming at?
moose said:
Yes.
Yes, you're absolutely right.
As for the original poster, I calculated an acceleration of 4m/s/s, not 16. The time is close to my value.
The frictional force opposing movement is 0.57*(229 + 261)N
=279.3 N
ma = 372.7 - 279.3 = 93.4 Newtons,the mass is 229/9.8 = 23.4 Kg
a=93.4N/23.4Kg = 4 meters/sec^2
Since at^2/2 = distance ----------> sqrt(2*distance/a) = t = 1.58 sec
yes yes i finaly got it thanks guys
