Calculating Specific Heat Capacity of Oil-Water Mixture
  • Thread starter Thread starter ergonomics
    Mixture Physics
The discussion centers on calculating the specific heat capacity of an oil-water mixture, specifically 3 kg of water and 4 kg of oil. It is established that the specific heat capacity of the mixture is the sum of the individual specific heat capacities of the two liquids. The participants clarify that while the individual components may heat at different rates, in equilibrium, the mixture reaches a uniform temperature, thus exhibiting a single specific heat capacity. This understanding is crucial for accurately determining thermal properties in mixtures.
  • Understanding of specific heat capacity concepts
  • Basic knowledge of thermodynamics
  • Familiarity with heat transfer principles
  • Ability to perform calculations involving mixtures
  • Research the specific heat capacities of common liquids, including water and oil
  • Study the principles of thermal equilibrium in mixtures
  • Explore the concept of heat transfer and its dependence on material properties
  • Learn about the mathematical formulation for calculating specific heat capacity in mixtures
Students and professionals in chemistry, physics, and engineering fields who are involved in thermal analysis and heat transfer calculations, particularly those working with liquid mixtures.
ergonomics
i am not sure if my question fits in this place.
if i have certain amounts of water and oil, 3kg and 4kg.
i mix them together, and i want to find the specific heat capacity of the mixture, according to my book the specific heat capacity of such a mixture is the sum of the two specific heat capacities of the liquids.
this does not really make any sense to me, if i put heat into the mixture shouldn't the water or the oil part of the mixture take longer to heat up?
does the heat transfer not depend on the heat capacity individually?
certain parts of the mixture are made of oil and water and therefore supposed to have different heat capacities, and yet when you put them into a mixture they all have the same heat capacity.
Chemistry news on Phys.org
Yes, the mixture has ONE heat capacity. While it may take different amounts of heat to raise the oil droplets and the water through a given change in temperature, you must accept that in equilibrium (ie: given enough time), the two phases reach the same temperature (by exchanging heat with each other).
Think in terms of mixture being black box seen from the outside - you don't see individual components being heated.
  • · Replies 28 ·
